Results 1 to 11 of 11
Thread: Turn Signal Wiring - 3 Wires | No Diagram
    Aug 2020
    All,
    On the turn signal there are 3 wires and no wiring diagram in the box, picture below, do you know what each wire is for? I'm not using a Ron Francis Harness...
    Below are the instructions from the manual?
    Wire the turn signals up to the chassis harness. On the light, the red wire is the dim light and the green
    wire is the bright light and the brass ring is the ground.
    Thanks in advance...
    Jun 2018
    North Vancouver, BC, Canada
    I believe dim (red) goes to the parking light wire, bright (green) is the turn signal...
    Gen 1 '33 Hot Rod #1104
    Jun 2019
    Gurnee, IL
    Black is Ground
    Yellow/Red stripe is Dim - Night indicator function
    Green wire is Bright - Turn Signal function
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Graduated
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55
    See if this helps:
    Norton, MA USA earth
    You really need to check them on a battery. Cant tall you how many I have found wired differently
    Falmouth, MA
    Ditto Mikes suggestion. They are not all colored coded the same. Simple battery test solves a lot of questions.
    Woodstock ,Illinois
    Testing each light before wiring is a must. Then ID them for later.
    Aug 2020
    All,
    Great Advice...
    Thanks for the guidance
    Dec 2018
    Sherwood Park, AB
    I have a bench DC power supply and I tested both configurations. Confirm that green is turn (bright) and yellow/red is park (dim).
    32J
    Folsom, CA
    literally one of my favorite tools, just for this type of stuff
    DYMO Industrial RhinoPRO 5200 Label Maker
    Todd
    Dec 2018
    Sherwood Park, AB
    Does that actually print on the heat shrink? Didn't know you can do that, if that's what it does.
