Results 1 to 5 of 5
Thread: almost ready to order my coyote and trans - check my list please :)
    Folsom, CA
    Going to buy from Mike Forte - here's the list of parts that I'm focused on - am I missing anything?
    1 M-6007-M50 M-6007-M50C 2018 GEN III ENGINE
    1 M-6017-M50 M-6017-M50B GEN III COYOTE ECU
    1 M-8600-M50 M-8600-M50BALT ALT KIT
    1 M-9680-M50 GEN III COYOTE ENGINE COVER KIT
    1 TCET17765 TKX .68 FORD TRANSMISSION
    1 COY BELLHOUSING, BLOCKPLATE & BOLT
    1 FORK COY CLUTCH FORK W/ PIVOT
    1 T/O B T/O B 614014 FORD LATE USA TIMKEN
    1 BOLT KIT & FLYWHEEL, CLUTCH BOLTS & PILOT
    1 M-6375 M-6375-G46A 8 BOLT FLYWHEEL
    1 RAM COY RAM 11" X 26 CLUTCH KIT
    1 MINI COYOTE MINI STARTER
    1 COY OIL COYOTE OIL FILTER NIPPLE
    1 ENGINE ENGINE LIFT PLATE COY ON LOAN
    LABOR-A ASSEMBLE TO TURNKEY & CRATE
    COY AIR K&N FILTER AIR INLET KIT
    I'm on the fence about the engine cover kit - but will probably develop something from it...
    the Tremec TKX is $200 more than the TK0-600 but that's par for the course
    Todd
    Jun 2019
    Gurnee, IL
    Are you running power steering? I would get a hydro setup if so. Also consider a QuickTime bell over the alum (assuming that’s what is listed).
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Graduated
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55
    Don't see the oil pan and pickup needed to replace the stock pan that's too low. Moroso is what I've used. For the Gen 3, you'll also need a BR3Z-6710-A Oil pan gasket/windage tray and bolts. Also you'll need a F3LY-6C070-A flywheel access hole plug. I personally prefer the lighter M-6375-M50 flywheel and the M-7560-T46 (Centerforce) clutch. But those are personal choices and I suspect Mike has his own opinion about what he's providing. Also curious about the starter. I've seen his packages not use the Motorcraft M-11000-C50 piece.
    Folsom, CA
    I'm pretty sure he does the oilpan already since it's turnkey ready, he assembles it all and ships in one huge crate... but I'll check!
    I found a new link on his site that shows the Moroso oilpan is an addon (see below)
    and yes, will upgrade to the steel bellhousing - you can't say "I wish I did that" after your ankles are blown away... better safe than sorry!
    I have the KRC power steering setup already from FFR so that's done
    I can check on the lighter flywheel, and Centerforce clutch - I prefer those myself
    • Ford Performance M-6007-M50C 2018 Gen 3 Coyote6
    • TKX Transmission (3 Gear Ratios Available)
    • M-6017-M50B Gen 3 Coyote ECU
    • M-8600-M50BALT Alternator Kit
    • Gen 3 Coyote Engine Cover Kit -Optional
    • Aluminum Bellhousing, Block-Plate, & Bolts
    • Clutch Fork/ Proper Pivot Ball
    • Timken Throw Out Bearing
    • Coyote Mini Starter
    • Coyote Oil Filter Nipple
    • Stock Flywheel -Optional Billet Flywheel Available-Lightweight Option Available
    • Ram Clutch 11″ 26 Spline, Optional Centerforce or Multi-Disc
    • -Optional Moroso Oil Pan and Pickup, Bolt Kit, Gasket, and Sensor Plug $632
    • -Optional K&N Cone Filter with Air Inlet and Adapters $154
    • Engine Lift Plate $95 (Refundable Upon Return with engine shipping brackets)
    • -Assembly Available Upon Request
    I need to add the hydraulic clutch - missed that previously!
    Thanks guys!
    Todd
    Folsom, CA
    bottomed out on this for my order
    Engine & Transmission Plans: Forte's Coyote Engine Package
    Tremec TKX TCET17765 FORD TKX 2.87 / .68
    QT RM-6080 4.6 COY TKX
    ACT COY 164T COYOTE FLYWHEEL 8 BOLT
    M-7560-T46 11" 26 SPL 4.6 CENTERFORCE
    MINI COYOTE MINI STARTER N/C
    OPTIONAL OPTIONAL PARTS & LABOR BELOW
    MOR COY GEN III PAN & PICKUP WITH GASKETS & BOLTS
    EXT HYD EXT HYD KIT MK IV MINUS MASTER
    ENGINE ENGINE LIFT PLATE COY REFUNDABLE $95.00
    + FREIGHT costs
    Todd
