Thread: Breeze - Cubby Door
    Aug 2020
    Breeze - Cubby Door
    All,
    I've cut out the Breeze Cubby Hole and now want to add a door to create a closed compartment.
    I've seen doors on the Cubby Hole before...
    What materials did you use?
    How did you go about making the door?
    How did you hinge it?
    Did you add a lock?
    I do plan on covering the door with leather...
    Thanks for all the help in advance...
    St. Helena Island, SC
    Another option (although a little pricey) is this marine glovebox. Remove a couple of screws and the tub comes off leaving you with a frame, hinge, and lockable door. Installed with nutserts.
    Folsom, CA
    this may work well, if you are doing the glovebox too - then you'll have a matched set!
    2PCS Push Button Lock Tool Box Latch for Truck Tool Box Lock Replacement
    Todd
    Nov 2019
    Charlottesville VA area
    I also have the Breeze cubby. I made sliding doors. They will be wood with veneer that matches the dash. I bought Z channel from McMaster-Carr and riveted to the panel. I made the top channel about 1/4 larger so I can insert the panel, push it up and then it drops into the lower track. I made them to the right width so the open to the max size.
    Vince
    Nov 2018
    Centennial, CO
    Quote Originally Posted by Padawan View Post
    All,
    Did you add a lock?
    I know Fixit did a pretty good write up on sliding doors on his build thread:
    40 Watt Garage - Mk4 Build - Breeze Cubby - Pt. 2
    Bradley
  6. Likes Fixit liked this post
    Oct 2020
    North Dakota
    I’m thinking about adding a door too
    Sep 2011
    My plan is one of the following - neither would cover it being "secured" against someone trying to break into it.
    1 - Use a piece of matching carpet, trim the edges to match the rest of the interior, and use snaps to hold the four corners in place
    2 - Cut a door out of aluminum, piano hinge it, and use a trimmed piece of carpet as a cover that's large enough to overlap the edges. That covers the edges plus covers the piano hinge. Can either use snaps or industrial velcro on the bottom edge to keep it shut.
