Results 1 to 2 of 2
Thread: Air Conditioning Condenser Mount
    Aug 2020
    All,
    1) How did you mount the condenser to the radiator?
    2) Will adding rivet nuts hurt the radiator because the rivet nuts will be pressing against the radiator?
    3) How close should the condenser be to the radiator?
    4) Do you want to mount the condenser high or low on the radiator/does it matter?
    http://www.northracecars.com/AirCon.html
    This is what I was thinking, with Rivets on the back....
    Thanks in advance...
    Richard Oben's Avatar
    Kansas City MO
    We get two long pieces of aluminum mount condenser to that and then with weather strip on all four edges mount it to the radiator. We just bolt it with some thin allen headcounter sunk to the condenser and allen to the Radiator. But every car is different. HTH, Richard.
