Likes Likes:  11
Results 1 to 10 of 10
Thread: 65 Coupe Sanding Done, Custom Blue Pearl Metallic Base Paint Applied
    Nov 2020
    Yarker, Ontario Canada
    With all of the sanding and body smoother completed (sanded to 600 Grit Sandpaper) the 65 Coupe was sealed with a grey sealer we tinted and applied the Custom Blue Pearl Metallic Base Paint to the complete body......
    https://youtu.be/9ERyp0U6lNg
  2. Likes Geoff H, WIS89 liked this post
    Nov 2020
    Photos of high build primer and smoother work. Also photos of Graphite Grey Sealer applied before Custom Blue Pearl Metallic Base Paint was applied.
    This important upgraded step of tinted sealer enhances the special pearls and metallic added to the Custom paint recipe we created to personalize the paint finish for the client.....
  4. Likes Geoff H, WIS89 liked this post
  5. #3
    Nov 2020
    With the Custom Blue Base Paint cured, the stripes are measured and masked in place on the body. Wimbledon White is used for the stripes and driver rear section.
    The rear driver side section is masked for its number 26 and painted with black base paint.
    The next step will be applying the High Gloss Clear Coat Finish....
  6. Likes Geoff H, WIS89 liked this post
  7. #4
    Dublin, OH
    love that color!
  8. Likes John Nizman liked this post
  9. #5
    John,
    Thanks for posting your videos for the Type-65 Coupe.
    Between you and Paul Borror (Edwardb), I'm feeling a lot better about the body fitment issues.
    Though I'm not ready to take the plunge yet, I'm starting to feel a bit better about taking on a future project.
  10. Likes John Nizman liked this post
  11. #6
    Nov 2020
    It is our pleasure to post these videos Steve.
    The main purpose for these YouTube Videos is to show the owner of the car the progress on their project (most clients live far away from our shop).
    The Bonus is other folks can view these videos to get ideas to help with their own projects.
    These kits are very well made, you just need to have patience and attention to detail for a very nice result!
    Thanks for viewing!
    John & Julie Nizman
  12. #7
    Nov 2020
  13. Likes Jkviper liked this post
  14. #8
    Nov 2020
    65 Coupe Painted Stripes & Numbers & Clear Coated, Doors Installed Too
    With the White stripes painted along with black painted on number, the body received 3 coats of Clear Coat Finish.
    Both doors were also masked and painted and also received clear coat finish.
    The doors were installed and adjusted to the body.
    The work on the front nose continues......
  15. #9
    Nov 2020
  16. Likes Jkviper liked this post
  17. #10
    Nov 2020
    The steps for the doors. After trimmed and fit to the body, they were sanded and smoothed and block sanded up to 400 grit sandpaper.
    Grey sealer was applied as a base coat before the Custom Blue Pearl Metallic Base Paint was applied.
    The masking was done for the "Bubble Gum Circle" then the black number was sprayed.
    With all masking removed, both complete doors received 3 coats of high gloss Clear Coat Finish and installed and adjusted to the car body....
  18. Likes Jkviper liked this post
