nskaats liked this post
With both driver and passenger doors trimmed and fitting great, the side door frames were installed and adjusted.
The rear spoiler was trimmed and shaped first. A special bonding adhesive was used to attach the rear wing / rear spoiler to the rear end of the body.
Body smoother was used to smooth and contour and blend the rear wing into the rear section of the body.
Next task will be the front end / front nose measuring, cutting, trim and adjustments......
More Progress on the FFR 65 Coupe Build.....
You're Really Making Me Want To Build One Of These Things!
..............Thanks For Sharing Your Build Videos!
