Thanks Thanks:  84
Likes Likes:  481
Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 685
Thread: 25th MKIV #9772 Build NOR*CAL: new vanity plate
  1. #161
    Folsom, CA
    Todd, I found when using these AN fittings you need to push the olive flush against the vice to bottom them out on the hose before tightening down and using lube on the threads is a big help aiding in tightening them down. I also trimmed a little off the steel braid back around the olive nut before tightening them. Have you tried to tighten those fittings a little more before pulling them apart? Sometimes they need just a little more to complete the seal.
    yep, I've done a few extra turns on them - the Fragola fittings I purchased are the zinc covered steel ones, they tear up my aluminum AN wrench something fierce...
    at this point the joints are binding a bit so I can redo them - the olives are only $2/ea. and I left a little extra fuel line slack so it should still fit
    Todd
  2. #162
    May 2020
    Make sure you have any steel braid trimmed back so it doesnt get in the threads, but just enough. If you trim the braid back too far you wont get enough compression on the olive to the tube even with the fitting tightened all the way together.
  3. Likes toadster liked this post
  4. #163
    Folsom, CA
    Quote Originally Posted by Hoooper View Post
    Thanks Hooper! yes, I ordered a few new fittings - got them at a 45-degree angle for better aesthetics - plus they're aluminum Fragola so it should be a bit easier.. plus I'll use some lube to ensure smooth tightening
    Todd
  5. #164
    Folsom, CA
    thanks to @Fman he was gracious enough to haul my body up to Ken Pike since he was getting his car back from fitting
    last time on the buck, and in Ken's shop!
    Todd
  6. Likes Kmcallahan, Fman liked this post
  7. #165
    Folsom, CA
    argh, more attempts - went through 4 ferrules/olives - got to the point that there was no audible leak, but failed the water test
    this one was trimmed too far back, so I used a blade to shorten the PTFE
    ferrule is flat on the top of the PTFE liner
    any ideas what I may be doing wrong here?
    Todd
  8. #166
    Apr 2019
    NC
    Most likely incompatible fitting and hose. The Fragola fitting is for ptfe hose. In the question and answer about e85 for that Kraken hose says it's not ptfe lined.
    Get the Fragola hose https://pitstopusa.com/i-23901885-fr...tegory:1206463
  9. #167
    Folsom, CA
    Quote Originally Posted by Greg K View Post
    sadly it's the Fragola hose and ends!!...
    Todd
  10. #168
    Apr 2019
    NC
    The link above in post #161 is what led me to a different hose that I thought you were using.
  11. #169
    Folsom, CA
    using FRA-602006 from summit
    Todd
  12. #170
    Folsom, CA
    just to follow up, got some new olives and will give another go... one thing I've been thinking is that maybe I'm putting too much air pressure in the line to test?
    also, found some instructions that shows that you push the PTFE lining .125" past the ferrule? First I've seen that - what is everyone's take on this setup?
    http://www.siliconeintakes.com/braid...es-p-1201.html
    Todd
  13. #171
    Jan 2020
    State of Jefferson
    Todd, what pressure are you testing at? FWIW I did 65 lbs on my entire system and it held pressure. One thing to consider you do not need to bottom out the fitting when tightening them down. There can be a gap in between the two fittings and still seal up properly. I am wondering if you are possibly over tightening the ferrule? Definitely do not need to go gorilla strength tight. I used the same line as you but did use aluminum fittings which really should not make a difference. Another tip is to push the ferrule into the side of the vice and bottom it out on the PTFE line before tightening it down. Lastly, make sure and put lube on the threads this really made a difference.
    Hope this helps you out...
  14. Likes toadster liked this post
  15. #172
    May 2020
    If you are using the fittings and olives it looks like you are using, you cant push the line all the way through the olive. There is a stop at the top of the olive that the line is meant to push against. If you have a ferrule type that is straight through on the inside then yeah the line should extend past the end of the ferrule.
    For pressure testing, what are you testing to? It shouldnt be anywhere near the limit of these fittings and hoses either way, the assembled hoses are rated as high as 2,000 PSI. Mine held 100 PSI of fuel pressure no problem when testing
  16. #173
    Folsom, CA
    Got 3 of 4 sealed
    need 1 more olive to seal up!!
    Todd
  17. #174
    Jan 2020
    State of Jefferson
    Got 3 of 4 sealed
    Awesome, what did you end up changing? Glad it is working out for you!
  18. #175
    Folsom, CA
    Finally got 3 of 4 PTFE ends air-tight
    I’ve determined that I’ll ruin every aluminum fitting - so I’ll stick with the zinc covered steel
    I went with some zinc/steel earl's fittings with the brass olive, they seem to be working better... every one of my aluminum fittings got stripped
    been busy with work this week, need to finalize this and move along
    Todd
  19. #176
    Folsom, CA
    ok - holy smokes - I'm still alive guys!
    A few months has passed, and sadly I was kept away from the build...
    so some updates:
    the body was taken to Ken Pike
    I donated my body buck,
    and the initial body prep is done!
    I have a LOT to do to get the car ready for fitment!
    Todd
  20. Likes JB in NOVA liked this post
  21. #177
    Folsom, CA
    Tonight I was able to get the Russ Thompson turn signal mounted,
    I just need a few longer screws to get the bushing collar to have enough threads that I feel comfortable with the setup, I chose not to cut away more metal than was needed.
    pre-assembled the setup for fitment on the body, I found that it's a good idea to snug up the bushing between the 2 parts to align the holes a bit more, so I recommend a quick tighten and removal
    Thanks to @Fman, Tony & Russ Thompson - I was able to figure out which way the plate fits onto the MKIV mount
    drilling out took some time, but slow and steady and used some cutting oil to help keep the squeaks at bay! still cleaning up metal shavings!!
    Installing the steering shaft took a lot more effort than expected but I mounted just up till the 2nd washer was hidden as the instructions say...
    I'll get a few longer screws tomorrow as I wanted a bit more thread on the mount
    overall happy with the result - removed the signal stalk till later - no sense in accidentally breaking it!
    edit: I believe my 2ndary shaft was damaged somehow and both ends are a bit mushroomed
    Todd
  22. Thanks 460.465USMC thanked for this post
    Likes Fman liked this post
  23. #178
    Folsom, CA
    well, my steering shaft issue aside... I think I somehow buckled both ends of the 2nd shaft so I'm contacting FFR to get a new primary and secondary shaft with the washers, etc... sigh...
    back to the build, realized I had not put in the floor of the passenger side yet LOL whoops!
    made an aluminum and silicone pizza today
    felt good to make a little progress today!
    Todd
  24. Likes Fman, JB in NOVA liked this post
  25. #179
    Folsom, CA
    ok - got the fuel lines run tonight... I think all this time I just haven't been tightening down the union joints enough!! so basically threw away $100 of AN fittings and olives.. oh well, live and learn!
    Here are the fuel lines from tank to engine bay...
    from the tank
    down the passenger backside
    under the passenger tube - they'll straighten out once the fittings are set in the engine bay
    loose in the engine bay until I finalize the insulation and determine the pressure regulator location
    here are the screws I used to go through the mounts and into the chassis
    1/4-20 x 1" Socket Head Cap Screws, Allen Socket Drive, Stainless Steel 18-8 (304)
    -6AN Hose Separator Clamp - Fuel line Mounting Clamps, Aluminum Hose Fitting Adapter
    full details on my fuel setup
    https://cobradreams.com/2020/07/17/ordered-my-flex-fuel-line/
    Todd
  26. Likes Fman, JB in NOVA, Kmcallahan liked this post
  27. #180
    Folsom, CA
    more odds and ends work today...
    after some struggling to mount the reservoirs next to the vacuum brake booster, I finally decided to mount the reservoirs on the firewall due to so many conflicts with the booster area
    I'll figure out some type of cover for the Jamar etched logo - not a priority right now....
    This setup should have enough room with a coyote engine and it will facilitate a really short hop to the clutch master, and will have to feed the brake booster through the side of the driver box
    next was to setup the driver footbox, I thought I had lost the panels but found them and assembled with clecos - not ready for final fit just yet - but it's darn close
    next was to use some extra aluminum panel to fill in the passenger side floor since I'm not using the handbrake
    lastly, I started to assemble the mesh screen to cover the radiator, sadly my brain was thinking in 2D and I only got enough aluminum 1/2 to do one side, so tomorrow I'll finish up once I make yet another trip to Home Depot
    Todd
  28. Likes Fman liked this post
  29. #181
    Jan 2020
    State of Jefferson
    Nice work on the Jamar, looking good!
  30. Likes toadster liked this post
  31. #182
    Folsom, CA
    finally got the radiator cover installed today - got the idea from Eddie (vSpeeds) and Travis (Fman)
    I think the mod adds a nice look, should protect the radiator, and only about $50 and a few hours of drilling, snipping, aligning, riveting, innovating
    ordered the 24x36 sheet from Pegasus Auto
    I had to trim it down to fit the front of the radiator, I ended up at 22.5" W and 20" H it's a bit long on the bottom, could have cinched it up another 1/2 inch, 19.5 H would place the lower bar just in the middle of the radiator tab
    I don't have a drill press, so all this was done by hand, gets tricky when aligning two bar together to not have the bottom one walk away on you
    I used a cleco to initially hold the bars together, then used 2 zip-ties to lock in the x,y,z axis which worked out pretty well IMHO
    getting everything aligned, clecos help a LOT here
    I left the mesh a little wide, maybe 1 square to ensure I was getting enough mesh in the bars
    To clean it up, it was easy enough once held together to pull a wide vertical strand down the outer edge and dremel off the horizonal matrix on the outside
    The top spring clips worked great to hold the upper mesh, but the bottom needed some support, I found a few ABS spacers in my toolbox and some stainless bolts, lock washers and nuts
    one at each lower corner, just drilled out the rivet and it aligned perfectly with the lower radiator tab... took a pic, maybe hard to see
    this ensures the shield is solidly mounted and won't move/damage the radiator itself
    here's my before and after pics - I think it turned out great!
    Todd
  32. Likes John Ibele liked this post
  33. #183
    Apr 2020
    Virginia
    Nice! I'm adding that to my to-do list.
  34. Thanks toadster thanked for this post
    Likes toadster, Fman liked this post
  35. #184
    Folsom, CA
    slowly chipping away at the brake/clutch reservoir plumbing...
    the 3/8" tubing I got from Whitby was about 2-5" too short for my setup, so I had to shop around to find some brake ready hose
    I also took the time to swap out my 1/8" NPT for the clutch line to a 1/4" barb, the 3/8" barb was too big and this fits up better.
    before running the reservoir lines, I've been on the hunt for some grommets that will keep the lines intact, no cuts and keep the engine bay heat from creeping into the footbox.
    I found the RPC 1" x 1.25" ones fit one of the footbox holes perfectly given the extra depth with the steel plate - but the one closest to the clutch needs a 1.3-1.5" OD grommet - need to keep hunting!
    for the inner wall I found a collection of grommets from Harbor Freight that work perfectly for the thinner aluminum sheet metal, but first had to make some holes
    I quickly realized that the top of the inner footbox was not 'level' so I had to do some quick measurements
    Step drill bits are probably one of the best inventions ever! 7/8" center hole, and 1" on both side holes
    You may notice that it's "BIG small BIG" hole placement - I went off the tightness of the NTP on the reservoir and alternated the outputs so they can route around each other.
    overall pleased with how it turned out, still need one more grommet to run to the brake booster, tomorrow is another day!
    on a side note, I talked with Mike Forte this week and updated my first post with the order sheet - waiting for the tax man update, then will pull the trigger on the Coyote and TKX
    Todd
  36. Likes Fman liked this post
  37. #185
    Folsom, CA
    reservoirs fully connected today to the vacuum booster, I'll figure out some type of foam to fill the gaps around the two 3/8"s hoses
    I was also able to fully mount the driver's floor
    the driver's inside panel needed more fitment so I can add the ThermoTec on the inside
    Since I was on a roll, I decided to align the whole top part of the box and prep the hatch... just a few clecos for now, but will add nutserts to ease access
    I think next steps are to install the passenger side floor, and get on my brake lines already!
    Todd
  38. Likes Fman, bldr.rob liked this post
  39. #186
    Folsom, CA
    last night worked on fitting and setting the passenger floor pan
    I had to remove the handbrake mount on the chassis since I'm going with the Wilwood EPB, quick work with a sawzall, cleaned up with a dremel, and painted the bare spots
    then it was fit, drill, clean, verify the holes, silicone, and rivet into place!
    I told my wife she could officially sit in my car last night, but she passed until there's a seat!
    Todd
  40. Likes bldr.rob, Fman liked this post
  41. #187
    Dec 2019
    Austin, TX
    Really coming together! Love the frame color. One thing I noticed, and you may have already accounted for but with the reservoirs mounted on the firewall it may be challenging to check the levels and/or fill them once the body is on. Just a thought. ....
    Mark IV Complete kit delivered 7/7/20
    Blueprint 427 ordered 11/23/20
  42. Thanks toadster thanked for this post
  43. #188
    Folsom, CA
    Quote Originally Posted by bldr.rob View Post
    Thanks! it's going slow, but progress is progress
    yes the reservoirs will be tough to check, unfortunately options are limited though given the vacuum booster - i spun on that placement for way too long and just bit the bullet and will learn to live with it
    in hindsight, would have done the hydroboost to save space in that area... not that I couldn't change it now but I'm pretty deep into that segment already...
    Todd
  44. #189
    Feb 2020
    Chicago
    Looking Good, Keep it up!
  45. Likes toadster liked this post
  46. #190
    Folsom, CA
    closed up the gas tank mount that won't be used, and mapping out the drop trunk ideas...
    determining whether I flush cut against the rails and drop the box in from top, or bend tabs down from the trunk and rivet the floor of the drop trunk to the drop tabs?
    also drilled out the fuel sender access port
    Todd
  47. #191
    Apr 2020
    Virginia
    Regarding your drop-trunk ideas, I was thrown for a loop until I remembered that you installed a non-standard gas tank (like, why is the fuel sender on the other side???). As a newbie, I've got nothing else to add, other than your build is looking great. Good luck with your custom drop-trunk!
  48. Thanks toadster thanked for this post
  49. #192
    Folsom, CA
    worked on setting up my ABS controller, I've been so back and forth on this setup - but I figured I have all the parts so I darn well should set it up!
    I'm drafting off @johngeorge setup with the GT500 ABS module http://www.johngeorgeracing.com/wordpress/2015/12/
    I don't know johngeorge but everyone who DOES know him says he's a legit dude with racing cred
    trusting blindly
    I have the Mustang HCU with GT500 module, not the FR500S module - that's for slicks, the GT500 module is for road tires - so perfect!
    Believe it or not, I got the whole setup for about $160 - but now the fun part - where do you mount an ABS module on an FFR?
    now, when you get the HCU and bracket from a Mustang - it isn't designed to fit a custom car like the FFR
    so I had to do some measurements and figure out how the heck this will mount on the MKIV - perfect spot next to the Breeze battery box
    IMG_2403.jpg a local pizza box will do for the mockup for a sheetmetal box
    with the HCU mounted on top, I'd need a way to mount the bottom of the HCU to the bracket so 4 x M5 rivnuts will be used, but first I had to trim the bracket to get it to 'fit' the space
    this gave me the basic shape and I smoothed the edges on the grinding wheel to knock off the edges, and also used a brushed wheel to strip a lot of the paint and prep for some POR-15
    tonight I remembered why POR-15 is such a fickle product, the mini can that I had was sealed up REALLY tight since I had previously used it on the IRS pumpkin - as I was tearing up the lid the whole thing exploded, ruining my garage computer mouse, and blackening my hands like midnight... UGH! oh well, some dawn soap, and brillo pads (and a new mouse tomorrow) and back to work!
    Tomorrow I will set the rivnuts and make my super excellent sheetmetal box with my harbor freight metal brake LOL
    Todd
  50. Likes Fman liked this post
  51. #193
    Dublin, OH
    I just had a similar experience w/ POR this weekend. Not the exploding can part, but the stained hands. If you buy another can, instead of opening up the lid, drill 2 small holes through the lid opposite of each other. you pour what you need out into a cup and reseal the holes with small screws. you'll just need to unscrew the screws when you want to use it again. think of an old juice can or Hi-C can that you'd need to open with that triangular can opener.
  52. Likes toadster liked this post
  53. #194
    Folsom, CA
    haha - yes, that went through my head, about 2 seconds after the accident... it's very odd how your skin gets warm almost instantly when POR hits it...
    call it poor prep on my behalf, I thought I could open it without gloves on... lesson learned!!
    Todd
  54. #195
    Folsom, CA
    built my mounting box, note - my name is not Mark Breeze, quality does not come close to his battery box - but then again, it's just a mount for my ABS HCU, so it will be tucked down by the battery box
    Used my pizza box mockup to scribe the sheet metal, some extra parts from the anniv build came with un-powdercoated stuff so I'm recycling
    Since I have the cheapo Harbor Freight brake, I can't easily do keyed width bends, so I used my vice to do the initial bend - and cinched the rest with a hammer and square corner - not pretty -but functional
    This gave me the shelf to mount the HCU, so I drilled/matched the holes
    I left the HCU main bushing and bolt to sustain the mount as well as the bottom pins so it should be pretty secure with rivnuts on the plate
    I went to paint, it was dark outside and after my initial spray I realized that someone at the store had swapped color lids
    so I thought I was getting hammered black paint, and it ended up being a gray/tan hammertone... I'll paint over with some black tomorrow...
    extra rivet holes are pre-drilled so I can place in the car and drill into the 4" tubes and a couple rivets into the Breeze battery box as well - overall about 8 rivets to hold this in place
    Todd
  55. #196
    Jun 2017
    I basically mounted mine in the same place but used another Breeze battery box. Depending on how you mount it, you have to watch out for how far it sits down into the hole so you can still get the harness plugged in because of the 4" tube. I ended up having standoffs on the bottom of the ABS bracket. I also didn't like the way it felt by only sitting in the post/rubber fittings from the bottom and the bolt on the one side. So I bolted it on both sides, from that ear on the bracket and then through the front of the Breeze battery box with a think rubber washer between the two.
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
  56. #197
    Folsom, CA
    Quote Originally Posted by Hacksaw84 View Post
    awesome - yep, I'm inverting my 'bucket' so the ABS HCU will sit on top (not down in) of the box
    lookin good!!!
    Todd
  57. Likes Hacksaw84 liked this post
  58. #198
    Folsom, CA
    it's taken me a few days to finally get this setup, but the ABS HCU is mounted and I have a battery in the car!
    my nutsert method didn't work out, I just couldn't get them to bind over 8mm, so I went with some long 3/16" rivets and it worked great!
    Todd
  59. #199
    Jan 2020
    State of Jefferson
    Looking good Todd, that ABS is going to be a sweet setup.
  60. Likes toadster liked this post
  61. #200
    Dec 2020
    Denver
    Hey Todd, great info. Quick question (John George's thread on ABS has some dead pics): For the GT500 ABS you can use the tone ring that's already mounted on the SN95 hubs (but maybe with some different sensors) and then use .... whatever magic magnets comes on the CV axles in the back with the sensor you called out? Or is there a seperate tone ring you need to separately mount to those hubs?
    Juan
    Juan
    Roadster kit received June 9th, 2021. First wrench turned July 7, 2021. Gen 2 Coyote in the mail August '21.
    Quantum Mechanic's Garage Build Thread
  62. Likes toadster liked this post
