While reading the other threads, I didn't see my answer.
I have ordered both of these and have them (plugs for both, they are fantastic if you are on the fence about them).
1st: Can I wire the turn signal direct into the Ron Francis system as per the Ron Francis instructions? I believe it has the relays already in it, so I shouldn't need to add them as per the Russ Thompson instructions, correct?
2nd: I understand the turn stalk button is not rated for much power running through it and needs a relay for the horn, or high beams, etc... I was considering using it for my clutch position sensor that allows the car to start. Would I need to add a relay for the switch? And which one would work for that?
And finally, on a different note, I plugged the Ron Francis headlight connector to the FFR provided pull switch for dash and headlights. For high beams, I want it going through a switch and indicator light on the dash. That's as simple as running the Ron Francis HB wire through the switch and light at this point, correct?
Wiring is not my thing, and so thank you in advance!
