Thread: T5 with S10 Tail Finished Interior - Looking for Pictures
    Aug 2020
    All,
    Does anyone have any pictures using the T5 w/ S10 tail where the interior is finished?
    Matt
    with the offset Viper shifter
    Idaho Falls, ID
    FFR7859 - graduated 5/16/16; '11 Mustang 5.0 'vert; '93 Mustang Notch; '98 F150; 4760 build website; FFR-3144 rebuild
    Spicewood, Texas
    Here's mine. It is a Hurst shifter for a T5 equipped Camaro(which fits the S10 tail shaft). It is the straight, flat stick. Just like the old "super shifter" I used in my drag car back in the 70's It's in neutral in the photo so you can see it sticks straight up. I heated the base and bent it until the angle was exactly what I wanted. You also can shorten the stick if you so desire. it shifts really, really good.
    Feb 2014
    San Ramon, CA
    Just completed my interior. Here's a couple of views.
    20201208_172000 by Rick Paul, on Flickr
    20201208_171929 by Rick Paul, on Flickr
    Was not happy with the shift and brake handle boots that I found, so I made my own. Used the same vinyl as the dash and the trans tunnel cover.
    Rick
    Aug 2020
    T5 S10 — Pictures
    Quote Originally Posted by EZ$ View Post
    Thanks for the prompt replies...
