All,
I've got a base kit where I upgraded just about everything...but on the other side comes situations where I am lost...
What Fuel Filter do I need? Can I order a plain stock fuel filter off autozone or rockauto? If not, what specs should I be looking for in a fuel filter? Is there a good balance between quality and price...
Then what regulator would you recommend?
Where do you buy fuel line Quick Connect Connections...
Keep in mind...I have not idea what I'm doing, figuring it out one step at a time...
I have 190 LPH Intake Fuel Pump 3/8 - fuel line out...
No racing only cruising (ok it maybe it'll hit a road race track once), but its being built for cruising...
302k
AFR 165 Heads
E303 Cam
Road Race Oil Pan
T5 with S10 tail
Matt
