10-09-2020, 10:15 PM
#201
Fman, for what it's worth, I just bled my hydraulic clutch today and here is how it looks at both extremes of pedal travel:
(at rest)
(fully depressed)
My pedal basically hits the floor at full travel, and I don't see any piston exposure or O-ring exposure. I adjusted the MC set screw (bolt?) a bit to ensure full engagement of the clutch well before it hits the floor. I'm average height and don't want to have to work that hard to shift gears!
Obviously, I'm just a newbie, so take my comments accordingly.
MKIV Complete Kit #9822 l BluePrint 347 EFI l TKO600 l Power Steering l Heater/Defrost l
Fman thanked for this post
Fman liked this post
10-10-2020, 10:47 AM
#202
I think the advise is for the slave cyl.
Good luck,
10-10-2020, 07:31 PM
#203
That’s correct. My mistake. It was for the external slave cylinder. I did install a simple pedal
Stop once I knew the clutch was disengaged. A little piece of kind to know it won’t happen again.
Scott
Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
10-10-2020, 08:56 PM
#204
Fman do you know where to get that awesome air filter. I am looking for that exact one. Thanks!!!
Fman
I was able to pick up my engine today along with my tk0600 and QT bellhousing. The engine has a few bolt on items remaining to be completed which I will take care of myself. Unfortunately after I got home and was looking over the engine I noticed the oil pan is 8" deep which I think is not going to work and hang down below the frame rail. I am a little bummed about this because I requested a 7.5" deep oil pan. Not a huge deal but a little bit of a buzz kill of the hype of the new engine.... Oh well, things happen and we will have to switch it out. If anyone has a link for a good 7.5" pan please send it my way, I found a Moroso 20534 that I think will get the job done.
I was also able to get my tko600 tailshaft cut off and started coming up with a game plan for mating up the TKO an QT BH. My engine builder already spec'd everything for me and installed my clutch, he said just bolt it together and should be good to go. The clutch fork is the only thing I have to do some more research on, I believe it needs to be at 90 degress with BH attached to the engine and TOB touching clutch? Maybe someone could confirm this is how I should do it? It seems pretty straight forward but definitely want to make sure I do this correctly.
Here is the Dart 427 with the Edelbrock Pro Flo 4
Here is the Canton oil pan at 8" deep, I ran a level on it and it definitely looks too low to me...... bumma! my engine builder wants me to install everything and see where everything lands. He said he would install another pan later on if needed.
Tko tailshaft cut down, I ended up using a sawzall to cut it
Looks like another trip to Ace, these bolts that were sent with my transmission mounts are not even close to being long enough. Not quite sure what they were thinking on this one? EDIT: these short two bolts are for the underside of the mount, the two longer bolts that attach to the transmission do not come with the mounts.
10-11-2020, 10:32 AM
#205
nucjd19, I picked up that air cleaner from Ansen valve covers, they can custom make you any graphic you desire. I did the air cleaner as a set with my valve covers, great guys to work with and there prices are very reasonable.
https://www.ansenvalvecovers.com/
10-11-2020, 10:34 AM
#206
Sdonnel
Scott
Do you know how far the clutch fork should extend for full clutch engagement or does it just bottom out?
Thanks for the tip, I will definitely take a look at this once I bleed out the clutch.
10-11-2020, 08:54 PM
#207
Thank you for the link Fman. I know now where to get my air filter and valve covers. Much appreciated!
10-14-2020, 12:41 PM
#208
Great looking work so far, Travis, and man are you making fast progress! I haven't decided how to do my vents yet, but yours look clean and straightforward ... a good example to bookmark and copy. Thanks and good luck as you get ready to turn the key
Meandering, leisurely build thread is
here
10-14-2020, 10:10 PM
#209
I was able to take a few more steps up the mountain... I got my FFR headers, Gas'n pipes, driveline installed, fluids filled in IRS center diff, tko600, shifter and my engine ground strap attached to the frame. I was also able to fine tune in my Forte throttle linkage, the adjustable bracket in the footbox was touching the top of the footbox panel at full throttle. This made me a little nervous so I ended up shaving off (1/16-1/8) top of the bracket to clear the top of the footbox, all good now.
I also had a fail bleeding out my Forte hydraulic clutch, at full extension the slave cylinder center piston came out, pivoted and got jammed with the clutch fork compressed. It was a little of a debacle but my dad and I were able to get everything apart, luckily I don't think I did any damage to the slave cylinder or the piston. This was my fault, I cut the linkage shaft too short. I contacted Forte and he told me to add 1/2" in length with a new bolt to get it dialed in correctly. Live and learn, part of the process....
Installing the driveline was a complete headache, what I thought would be a half hour job turned into three hours. A couple tips, the transmission needs to be resting against the cross member in order to achieve the straightest line of site to slide in the driveshaft. It was still a struggle to get the driveshaft to slide in and a relief when it went in, I read one thread about someone actually taking there engine back out to get it in. I also removed the center donut, I really cant see how you could get it in with the donut on but Tremec does say it is possible to do it. Upon my research most seem to just take it out.
Here is a pic of the donut before and after removed. Be very careful removing it, I used two needle nose pliers on each side and avoided pinching the outer part of the seal. With a few good tugs it came out.
Donut removed, a good idea to inspect the inner seal to make sure it is not folded over or damaged.
Driveshaft installed, I ended up using three spacers from Forte to get the angle almost straight. I still need to run the Tremec app on it to confirm it is within specs, more on this to come. I ended up doing 50 ft/lbs on the six bolts on the center diff adaptor plate and 80 ft/lbs on the four bolts holding the driveshaft. I also used blue loctite on all of them.
Forte spacers
I used 75w-85 (3/4 qt top off) for the rear IRS and AC Delco synchromesh for the TKO600 (almost 3 qts). One surprise is when I found out Ford is now filling the center diff before shipping, it was about 3/4 qt down before coming out the fill plug. I called FFR and they confirmed for me to top it off and no need to add the friction modifier as Ford is now doing this.
Also got my FFR gearshfter mounted to the Tremec 600, it looks like a nice shifter. Probably will end up replacing the shift ball with something different.
Shizzzel!!! my Gas'n Pipes arrived.... as many have mentioned these are a work of art. Totally worth the five month wait, the craftsmanship is incredible. I also installed my FFR stainless headers, my engine builder recommended a Felpro 1415 gasket anti-seize on each bolt and 1" long 6 pt header bolts. He mentioned I would need to re-check a couple times after a few heat cycles.
Post Thanks / Like - 1 Thanks, 2 Likes
10-14-2020, 11:05 PM
#210
25th Anniversary #9772
dang that's lookin legit Travis!!! nice job!
10-14-2020, 11:13 PM
#211
The pipes look fantastic Travis!
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
10-16-2020, 04:55 PM
#212
Nice work! I can almost hear your engine starting now.
10-21-2020, 09:51 PM
#213
10-22-2020, 10:25 AM
#214
Looks good, you will love the Gas'n Pipes. I was at the Cars and Coffee last weekend as well; I was amazed how many nice cars were there.
10-27-2020, 04:50 PM
#215
10-27-2020, 10:36 PM
#216
The Boig tubes look great. Have them on my Coupe build and very happy with them. Good choice on the T-clamps. Those things work great. One suggestion. After a few heat cycles, go back and snug them up one more time. I've usually found that necessary. Shouldn't have to touch them again after that.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
10-28-2020, 07:17 AM
#217
Very nice! Looking great.
10-28-2020, 11:12 AM
#218
edwardb
Thank you, I will definitely put that on my check list!
11-09-2020, 07:32 PM
#219
11-09-2020, 07:38 PM
#220
11-09-2020, 11:40 PM
#221
Fman, your build is looking amazing! Very clean and professional-like. Off-topic question: what is your hydraulic lift system? I think I'm ready to upgrade from jack stands.
11-10-2020, 12:27 AM
#222
JB in NOVA
This leaky water neck is going to put me in the crazy house... fingers crossed I can get it figured out this week!
JB, highly recommend a lift if you like working on cars.... game changer for sure on all counts. Your back and knees will also appreciate it! Here is the lift I purchased, it was about $600 to install it and another $300 for electrician to wire it for me. I went with this lift because it is wider at 115" which is nice to be able to get the doors open easier. The lift is made by VSG who also owns Rotary and Direct lifts. One suggestion would be to make sure you get ALI certified lift, there are some on the market today who don't have this certification.
I have had my Tundra up on the lift with no issues and it weighs around 5600 lbs.
http://shopequipmentlift.com/two-post-lifts/apex-pl10/
11-10-2020, 03:32 AM
#223
Fman
Fman, you are really close. I had the same problem with my water neck. Except mine was leaking while driving. It is amazing what a mess that can cause underneath of your car and down the right frame tube. I had mine on and off about 3 times as well. I think that you are on the right track with your components now. I was using the Mr Gasket chrome water neck. The parts that I ended up using that was finally leak free:
Ford Performance water neck with Felpro gasket
Thermostat held in place with RTV (3 little dabs is all you need) and let sit overnight. You are correct that this keeps it in place when mounting it up.
Good luck. I also lost a LOT of time on this. Don't forget to snug the two bolts up after a few heat cycles.
11-10-2020, 02:05 PM
#224
TMartinLVNV
What you purchased is exactly what I will be using, even my BIL who helped me the second try said I have a bad water neck. Thanks for the tip about rechecking the bolts, I will definitely do that!
11-11-2020, 08:11 PM
#225
Wow! It's really coming together nicely! Congrats! Looking forward to the video.
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
11-12-2020, 06:18 PM
#226
Cooling upgrades, start up video and first Go-Kart!
Finally some success, fourth time is a charm... my leaking water neck is now sealed up! Amazing what a good part can do, the Ford Racing water neck fit perfect and no leaks!!!
I was also waffling on upgrading my overflow tank and cooling fan, figured now is much easier to do it then waiting after the body is on. The FFR tank is less than 1 qt (.91) I picked up a 2 qt Canton, I like the extra holding capacity. I also did some research on the FFR cooling fan, it is rated at 2170 CFM, the minimum rating for a V8 is 2500 CFM so I decided not to chance anything and picked up a Flex-a-lite lowboy 3000 CFM puller. Both were a very easy install and now I feel confident I have maximum cooling capability.
Here is the Flex-a-lite fan, rated at 3000 CFM. It is also a little quieter than the FFR and draws the same amount of amps.
https://www.summitracing.com/parts/flx-238
Canton 2 qt overflow tank, it also has a nice site gauge on the side of it which lets you know where the current level is
https://www.summitracing.com/parts/ctr-80-201
Final picture of Engine after wiring is cleaned up
And here is a video of my first non-leak start up, I also was happy to see my temperatures are stabilizing. I was also able to go-kart around the neighborhood.... I am still alive, nothing caught on fire and I made it home. Transmission shifted good, clutch felt good, so far everything is moving in the right direction!
I still need to adjust my IAC down, it is high at 48% right now, that will be my next task on the EFI.
Post Thanks / Like - 0 Thanks, 4 Likes
11-12-2020, 07:13 PM
#227
That's awesome. Congratulations!
Build thread here.
11-12-2020, 09:28 PM
#228
Not leaving drips of anything on your driveway is priceless. Congratulations! It is sounding great!
11-12-2020, 10:35 PM
#229
Just an FYI. My local BAR referee required a closed PCV system. This meant a PCV valve plumbed as yours is to a vacuum port and a breather on the other valve cover plumbed to the air filter. One thing my inspector pointed out ahead of time is that your hoses need to be rated for the PCV system. On my hoses the PCV side is identified with ridges along the hose. On the air cleaner side my hose I'm pretty sure it's printed right on it. The best thing I did is contact the BAR referee ahead of time and took a few minutes to discuss my build and his requirements. Did the same thing with CHP and Brake/Lamp/Safety inspection.
If you live in Commifornia you will need a PCV valve to pass SBC100 inspection so I ended up installing one
[/QUOTE]
F5R #7841: 15th Anniversary Edition MK4, Ford Racing Z427, Holley Terminator X Stealth EFI, Gas-N Pipes, Stainless Headers, Liberty's Gears TKO600, 3.31 Moser 3-Link, 17" Halibrands
11-12-2020, 10:52 PM
#230
CDXXVII
[/QUOTE]
Thanks for that info I appreciate it, my plan was to use another air cleaner for the other loop to pass inspection. I don't want to drill another hole in this one, it already has MAT sensor in the back of it for the EFI.
11-12-2020, 11:04 PM
#231
Oh wow, that sounds really good. Congrats! That mechanical throttle looks sharp!
11-14-2020, 01:37 PM
#232
Fman
Forte spacers
Interesting to see that Ford send the differential with some friction modifier and fluid, I added about a quart of it and friction modifier, hope the addition of the 4oz of added modifier doesn't affect the differential.
11-14-2020, 07:10 PM
#233
jiriza84641
I just did what FFR told me to do, I am no expert in rear diff's but IMO either way having it or not the differential would still be fine. It already has synthetic gear lube in it to begin with. I doubt adding more modifier would cause any problems.
11-15-2020, 08:33 AM
#234
build thread:
http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
Build School: July 14-16, 2017
Kit purchased: July 25, 2017
Kit delivered: September 13, 2017
First Start: December 22, 2018
Body painted and kit completed and drivable: July 2019 (but still not done)
CA SB100 Registration: January 2020
Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
11-15-2020, 08:44 AM
#235
Looking great! Where'd you get that air cleaner?
11-15-2020, 01:28 PM
#236
Vspeeds
looking good!
Thanks Eddie, appreciate all your help along with many others on this forum! Nice to have it fired up and running, I drop it off for body fitment first week of Dec to Ken.
11-15-2020, 01:31 PM
#237
cv2065
Thank you, I definitely used your build thread quite often!
I picked up the air cleaner from Ansen valve covers, they will do any custom logo for you and were excellent to work with. Jury is still out on my air cleaner with that air filter if it is going to clear the body. I might have to change the filter to a lower profile, will find out soon.
11-15-2020, 09:50 PM
#238
Nice work Travis
Looks top notch uhc
11-15-2020, 10:38 PM
#239
v1-vr
Nice work Travis
Looks top notch uhc
Thanks Dave, let me know when you need a second set of hands... I owe you one! Hope your build is going well...
11-15-2020, 11:33 PM
#240
Congrats, Travis! That is awesome. Been following your build since the beginning, and it's really coming together nice. Way to go!
MK4 Complete kit.
Build Thread.
