Results 1 to 5 of 5
Thread: Shifter Location - T5 w/ S10 Tail - Picture Request
    Aug 2020
    Dear Members,
    Does anyone have a picture of either: completed Roadster or a car in the go cart stage using a T5 with the S10 Tail Housing?
    I'm trying to see where the shifter location ends up in the finished car...
    Thanks in advance!!!
    -Matt
    MK4
    302 - 86 Block
    AFR165 Heads
    IRS
    Millis, MA
    This might help, the shifter ends up in the same place as a TKO with a mid shift kit.
    “Privateer”
    289 USRRC Chassis #9188 p/u 9/11/2017 Go kart 3/18/2018, road legal 6/16/2018
    Ford full roller 306 built by my son and me Holley Sniper EFI
    TKO600 2015 IRS 3:55. 17” FFR Hallibrand replicas, Power steering
    FFR Vintage instruments, Wipers and Heat/defrost
    Lots of parts and advice from Mike Forte & Mark Reynolds (Breeze Automotive)
    Aug 2020
    Chuckster,
    Did you have a picture of it install in the car?
    Thanks...
    Idaho Falls, ID
    If I remember right, the S10 position is exactly 8" forward of the Fox Mustang position...
    From my 3144 rebuild. The 3/4" frame tubes might have to be relocated...
    https://sites.google.com/site/ffr314...missionsurgery
    FFR7859 - graduated 5/16/16; '11 Mustang 5.0 'vert; '93 Mustang Notch; '98 F150; 4760 build website; FFR-3144 rebuild
    Las Vegas
    That looks about the same as how RyanH's came out, I forget his frame number now but it was an early Mark IV. We did the S10 swap on his T5. Just saw this shifter from American Powertrain on the other forum and was wondering if it would fit in the tunnel, but it looks like it should, might be a little taller than the S-10 shifter position though.T5-s10-offset-shifter.jpeg
