Swapped mine easy with no issues. Straight swap. Cut a nub off the bottom that hangs down below the rails. You'll need a chevy shifter. The mustang shifter does not bolt in. I do not need the speedo gear or electronic speedo pickup because I'm using a GPS speedo. Same drive shaft. The top cover that holds the forks from the C10 has a shorter shaft and uses the same forks. Easy swap.
Watch this video on youtube: https://www.youtube.com/watch?v=Dst89HqW8ow
https://thefactoryfiveforum.com/show...tock-swap-pics
https://www.ffcars.com/threads/pics-.../#post-6098558
Reason: add data
