Results 1 to 5 of 5
Thread: T5 with S10 Tail - Mounting
    Aug 2020
    I'm in the process of ordering a T5 w/ S10 Tail Housing...
    Will I still be able to use the standard Roadster 28 Spline 8.375" Driveshaft?
    Is it as simple as switching out the tail housing and from there its plug and play?
    Do I need to give the transmission builder any special instructions?
    Roadster Build:
    - 302 Motor
    - IRS
    - Power Steering
    - Power Brakes
    -15 Inch Wheel
    Spicewood, Texas
    I believe it depends on what output shaft the trans builder uses. I used an S10 shaft and had to switch the driveshaft yoke. So that would be a question for the builder. The length is the same. You will also need a shifter that fits a GM T5 as the base plate is different on on the S10 Tranny.
    Jan 2015
    I used the mustang output shaft,just swapped the housing. I believe the shift rail also needs to be changed to s10
    Spencerport, NY
    There is something inside that needs to be clearanced, I vaguely remember using a die-grinder to remove some aluminum. I also cut the shark-fin off of the bottom of the housing and fabricated a new mount. The speedo drive has to be modified also (but I use a GPS-driven electronic version of the Autometer guages so the drivetrain really doesn’t matter). It’s not completely plug-n-play but, IMHO, it’s a fantastic mod!
    George T
    Type 65 Coupe #338, Picked Up 4-Aug-07, Roller on 8-Mar-09, 1st start 8-Sep-13, 1st Autocross 7-Oct-18, finished sanding & sprayed paint myself 6-Nov-21, IRS/LCA/Koni/traditional gages/Kirkey/pin-drive rear width/15" Torq-Thrust Ds/44IDFs/Brodix ST5.0R heads/Eagle internal-balance crankshaft/oil pan by Armando/home-made turkey pan/S-10 mid-shift T5
    Swapped mine easy with no issues. Straight swap. Cut a nub off the bottom that hangs down below the rails. You'll need a chevy shifter. The mustang shifter does not bolt in. I do not need the speedo gear or electronic speedo pickup because I'm using a GPS speedo. Same drive shaft. The top cover that holds the forks from the C10 has a shorter shaft and uses the same forks. Easy swap.
    Watch this video on youtube: https://www.youtube.com/watch?v=Dst89HqW8ow
    https://thefactoryfiveforum.com/show...tock-swap-pics
    https://www.ffcars.com/threads/pics-.../#post-6098558
