Results 1 to 10 of 10
Thread: New Engine Build - 302 | Intake Manifold Clearance Issues
    Aug 2020
    Will I run into any clearance issues with the Edelbrock Performer RPM Intake Manifold (https://www.summitracing.com/parts/edl-7121/make/ford)? From what I understand a dual plane manifold is better for street applications.
    Planning on running a HOLLEY SNIPER STEALTH 4150:
    https://www.holley.com/products/fuel.../parts/550-870
    Side note - Any recommendations on Rockers?
    Based on the forum advice... I'm going with AFR 165cc SBF Renegade 20 Degree Street Heads (https://www.summitracing.com/parts/afr-1399)
    302 Short Block Parts:
    Pistons: Federal Mogul
    Rings: Hasting
    Rods: FORM OEM
    Rod Bearings: Federal Mogul
    Main Bearings: Federal Mogul
    Cam Bearings: Melling
    Ear Main Seal: Fel Pro
    Gaskets: Fel Pro
    Roadster Setup:
    IRS
    Wilwood Pedal Box
    Power Steering - OEM Mustang Rack
    Power Brakes w/ https://www.whitbymotorcars.com/prod...-kit-complete/
    -Rear Brakes | FFR solution because I'm going with 15 inch rims
    -Front Brakes | Mustang OEM
    Fuel Tank | Mustang OEM
    Intank Fuel Pump | TBD
    15 inch Rims
    T5 Transmission
    302 Engine
    I have a dual plane manifold with a Sniper EFI on it. There is a 1/2 inch open spacer under the Sniper and a 3/8 inch air cleaner spacer on top. My COBRA oval air cleaner has about 1/2 inch clearance under the rear engine bay cowl.
    Here is a link to a YouTube video I found during my research on installing the Sniper. I found the whole video informative but the section on dual plane manifolds starting at the 5:10 mark was very helpful. https://www.youtube.com/watch?v=M2u7d8kajVI
    Because of this I notched my intake divider a 1/2 inch in addition to running the 1/2 inch open spacer.
    HTH
    Norm
  3. Likes D Stand liked this post
    May 2018
    Merritt Island, FL
    What cam?
    Aug 2020
    Quote Originally Posted by davekp View Post
    What cam?
    E303 Cam
    Aug 2020
    Norm,
    Would the RPM Air Gap, Dual Plane Intake Manifold solve the for need to insert a spacer?
    https://www.summitracing.com/parts/edl-7521/make/ford
    HTH
    Norm
    It is the dual plane that causes the issues for the Sniper not the height of the manifold. Watch the YouTube video, especially the section on dual plane manifolds starting at 5:10. They explain it clearly. I used an open spacer and removed some of the centre separator of the dual plane manifold to solve that issue. The air cleaner spacer improves airflow because the shape of the oval COBRA air cleaner restricts airflow into the carb or Sniper especially with the thinner filter element.
    Norm
    Jul 2019
    One of the vendors here, Mike Forte', is extremely helpful with engine builds and has all the higher-end proven parts you'll need as well as a number of custom parts specific to our cars. If it were me (and it has been) giving Mike a call will make things go smoother, and he's saved me a good bit of $$$$$.
    I believe the air gap version is taller than the non air gap.
  10. #9
    Correct. With the Air Gap you run out of room for an air filter.
  11. #10
    Maybe I should have said, the Sniper doesn’t operate well on a dual plane manifold. You can make it work properly by removing some of the centre divider of the manifold or running a 1 inch thick open spacer. There is not enough clearance for that thick of spacer so, I ran a 1/2 inch open spacer and removed a 1/2 inch of the divider. This allowed me to run a 3/8 spacer on top of the Sniper for better airflow in from the air cleaner and give the air cleaner just enough clearance at the rear engine bay opening.
    A single plane manifold would be better if you are sure that you are not ever going to need the extra performance that a dual plane gives a carb.
    Norm
