Results 1 to 4 of 4
Thread: 302 Engine Build - Cylinder Heads | Intake Manifold | Stack-able EFI -- Advice Needed
    Aug 2020
    Good Evening,
    I've ordered a 302 short block with an E303 Cam and looking for advice on what Cylinder Heads | Intake Manifold | Stack-able EFI I should get...
    Quick Background: This Roadster is being built as a cruiser, no racing of any kind..
    Cylinder Heads?
    Intake manifold?
    Thinking about: HOLLEY SNIPER STEALTH 4150 with an Intank Fuel Pump?
    https://www.holley.com/products/fuel.../parts/550-870
    Thanks in advance...
    302 Short Block Parts:
    Pistons: Federal Mogul
    Rings: Hasting
    Rods: FORM OEM
    Rod Bearings: Federal Mogul
    Main Bearings: Federal Mogul
    Cam Bearings: Melling
    Ear Main Seal: Fel Pro
    Gaskets: Fel Pro
    Roadster Setup:
    IRS
    Wilwood Pedal Box
    Power Steering - OEM Mustang Rack
    Power Brakes w/ https://www.whitbymotorcars.com/prod...-kit-complete/
    -Rear Brakes | FFR solution because I'm going with 15 inch rims
    -Front Brakes | Mustang OEM
    Fuel Tank | Mustang OEM
    Intank Fuel Pump | TBD
    15 inch Rims
    T5 Transmission
    302 Engine
    Jun 2015
    Maumee, OH
    I had the AFR165’s on a 306. They were a very nice upgrade that really moved some air. They’re not cheap, but you don’t have to overhaul brand new heads like some of the other offerings out there.
    Scott
    Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
    Aug 2020
    Scott,
    Is this what you're referring to: https://www.summitracing.com/parts/afr-1402 ?
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    I have the Edelbrock E-Street heads and Air Gap intake with the Holley Sniper. I also have the Ford "E" cam. with my 347, it puts out 439 hp and 445 ft lbs. Not too shabby.
