Selling a new EFI Fuel system, complete from the tank forward.
Everything came from Factory Five and Mike Forte.
I went with a Boyds Racing setup so no longer need this.
All parts are NIB new and never used. As you can see in the pics, the tank was mounted temporarily but no fuel ever ran through this.
The parts list is as follows:
(1) Ford EFI Fuel Tank, black, new in the box. $150
(1) Fuel Tank Cover, black, new in the box $115
(1) Fuel Level Sending Unit $34
(1) Vapor Valve/vent $60
(2) Fuel Tank straps and (4) mounting bolts $27
(1) Fuel Filler Tube, (1) bracket, & (1) filler neck seal/grommet $70
(1) EFI Fuel Pump, 190 LPH & Hanger $189.00
Coyote Fuel Filter/Regulator Kit $130.00
(1) GM Fuel Filter/Regulator, 58 PSI static.
(6) Quick Connect fittings
(2) 4-foot Fuel Lines, 3/8" (.375"), Black Nylon
(1) 12-foot Fuel Line, 3/8" (.375"), Black Nylon
(10) cushion straps
Purchasing everything separately $775
Buy it all here as a kit $500
I prefer local pickup but wiling to ship at your cost.
I also have an extra EFI pickup for anyone else who just needs an EFI pickup. Normally $70. Buy it here for $50.
If you need the steel lines Supplied by FFR, I have those too.
