Results 1 to 5 of 5
Thread: 4-Port Heater Control Valve and Rear Expansion Tank Modification
    Central, FL
    In an attempt to begin making The Factory Five Forum as much of an info center as the FFCars forum here is the 4-Port Heater Control Valve (HCV) and Rear Expansion Tank Modification. Crash now sells a compete kit for this modification http://www.myraceshop.com/. He was sold out when I was at this stage of the build which is why I had to source the parts myself. You can use the diagram to gather the parts. All part number are on the diagram except for the "T" fitting and tank head fitting on required for the bottom and upper side of the expansion tank. I purchased them at home depot in the plumbing section and consist of four (4) pieces. I don't have the part numbers, but you can do what I did to ensure you leave the store with the correct items. I just brought the tank in with me.
    For further cooling system consolidation I am adding the part numbers for the engine side rubber hoses. Note that there are other rubber hoses that will fit the hoses as well. These are the part numbers used by Mike Downs.
    *Gates 20893 -Upper
    *Gates 20827 -Lower
    As I did on the other forum credit and thanks go to Crash and Richard for creation, R&D, question answers and a kit.
    Items required for the mod (part number on diagram):
    *Crash's Kit- http://www.myraceshop.com/
    Or
    *Canton Tank
    *Radiator Cap for Canton tank
    *Canton Tank "T" fitting
    *Canton Tank Head Fitting
    *4-Port HCV Valve
    *EGR Vacuum control valve
    *Vacuum Valve to vacuum Hose Adapters for EGR and HVC
    *Vacuum Line
    *Vacuum Valve Harness (pigtail) This is also the same harness as the donor's washer motor
    Rubber Hose Part Number:
    Here is a quote from Crash explaining what this modification addresses.
    The four port valve upgrade from the HCV is not a "requirement". As Artgirl said, you can run fluid through the heater core at all times and all will work fine, and this will solve the thermostat issue. However, the downside is that the Vintage air system was designed to use the HCV(supplied Heater Control Valve) to shut off the flow of coolant when the heater portion of the HVAC unit was not being used. What will happen to temps and efficiencies of the Vintage Air unit when in "max AC" mode without any valve being used? I really don't know. Maybe Vintage Air can answer that?
    The solution offered just keeps the Vintage Air system operating as designed by it's manufacturer, and also changes things a little so that the GM thermostat is operated as GM designed it as well. So the 4 port valve essentially just makes everything work as intended by the combination of manufacturers of both the AC unit and the engine.
    Use it, don't use it, plumb it differently, whatever. As the saying goes, "there is more than one way to skin a cat". If you absolutely know what you are doing and have considered all the potential consequences of changing things, then no problem. Build what you will. I offer this kit simply so that builders can make this stuff work as a "no brainer".
    And not trying to bash or demean anyone in any way. I am one of those guys that can't seem to leave well enough alone whenever I get something. I take it apart, I look at it for long periods of time, and I try and see if I can come up with a simplier, easier, cheaper, or better way, so I fully understand what you are saying and where you are coming from.
    If you do go your route of hooking into the lines that run through the tunnel instead of running lines to the thermostat housing area of the water pump, you will need to make sure that there is continuous flow to both sides of the thermostat. If all else fails, then just run a U tube connecting the inlet and outlet at the thermostat where the Vette heater hoses originally attached.
    However, if you want to also address the head steam vent issue, then putting a Header Tank kit on will address this AND allow water to flow to both sides of the thermostat. You can then put the 4 port valve anywhere you like before the heater core, or just use the HCV and just stop flow entirely in the hook up lines for the heater circuit.
    R/s
    Vidal
    CURRENT STATUS: Interior Rework and Bodywork.
    GenII GTM #331. Delivered (23/9/10)
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Mad Scientist
    Sep 2011
    Meadow Vista, CA
    "Start Thread Hijack"
    this is great information! would it be possible for you to post the part numbers of the radiator hoses that you found to fit?
    How about a thread that is "All Cooling Information" in one place?
    "Stop Thread Hijack"
    Thanks!!
    GTM #253 In Process
    http://www.jegs.com/c/Fittings-Hose/181705/10002/-1
    Your build deserves AN fittings.
    Central, FL
    Quote Originally Posted by mendo View Post
    Thanks!!
    I can get those and update the thread.
    Quote Originally Posted by fastthings View Post
    Thanks Gene.
    R/s
    Vidal
    San Diego
    Vidal,
    Thanks for starting this thread.
    Yes, www.myraceshop.com has these complete kits for sale. As with all the kits that are sold to address issues on the GTM build by www.myraceshop.com, you can certainly put the parts together yourself. All that is being offered by www.myraceshop.com is the convenience of not having to search and put parts together, etc. The extra $$ is very small compared to the time you save in sourcing parts IMHO, so it really comes down to whether one wants to save something in the area of $20-$30 by shopping around and trying different pieces, or just wants the convenience of buying a "kit" that addresses the problem in one order/shipment to your door.
    Header Tank Kits are here:
    http://www.myraceshop.com/Header_Tank.html
    Heater Bypass Valve Kits are here:
    http://www.myraceshop.com/Heater_Bypass_Valve.html
    Install instructions and pictures are also available at that site.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
