So I ordered the IRS because of obvious reasons, but what I didn't understand was how limited the brake options were. From what I understand I can complete the IRS with an 8.8 center, Torsen diff, and upgraded axles from a company like DiscBrakesRUs. Optionally I've read I can get the Cobra Roadster R hubs and rotors as long as I get a special bracket for the clippers (right?). Is this the best option?
So far I found these options for IRS brakes (reading FAQs and searching):
10.5" T-Bird Rotors and calipers (cross-drilled and slotted optional)
http://www.discbrakesrus.com/make/fo...rdrearkits.htm
11.65 Cobra Rotors and Calipers (cross-drilled and slotted optional)
http://www.discbrakesrus.com/make/fo...brarearkit.htm
13 inch Big Brake Rotors & Cobra Calipers (cross-drilled and slotted optional)
http://www.discbrakesrus.com/make/fo...sforirs8.8.htm
So what if I want to run the car on the track? Sadly, I cannot find a 2-pot rear caliper anywhere. I didn't see any brembo or wilwood options. Are better calipers even necessary for such a light car? I would think so knowing when you run more power you increase the speed and produce more brake heat, and need to consider brake upgrades to counter-balance this. This car will be getting a Coyote aluminator 5.0 and may see upwards of 430hp/400tq with intake/boss-manifold/tune. I know many of you run more power than that so wondering what your experiences were on the track and street.
Also, what else do I need to be thinking about with the IRS setup? All feedback welcome.
And no offense to the other vendors. DBRU was just one source that had options. I'd love to see what you have too.
