Thread: steering wheel horn button
    Folsom, CA
    what size/type needs to fit the FFR steering wheel?
    seems like this one 'may' fit?
    Black 6-Hole Universal Fit Aluminum Horn Button for Aftermarket Steering Wheels
    Todd
    Quote Originally Posted by toadster View Post
    Toadster,
    The F5 Wheel has an offbeat pattern.
    Equidistant it isn't.
    Woodstock ,Illinois
    You’ll have to drill and tap your own holes for the button. Not really a deal breaker... just something to do.
    Colorado Springs
    As said above, the FFR hub and wheel have an asymmetrical bolt pattern so it can only be put on one way.
    Also, that's just the button/switch. None of the other wiring or hardware exist on the FFR column. You'd have to install a new column that has all that; like Flaming River or Ididit.
    .boB "Iron Man"
    NASA Rocky Mountain, TTU #42, HPDE Instructor - Retired 10/24
    www.RacingTheExocet.com
    Nov 2016
    "The i.e." SoCal
    Quote Originally Posted by Bob Cowan View Post
    We've actually added a horn button to a number of cars utilizing the F5R steering shaft assembly. Not for the faint of heart but it's a lot less work than using an aftermarket steering column.
    Here is a link to a MK2 we did a number of years ago using a Grant steering wheel horn button we adapted utilizing a Ford Probe self cancelling unit and commutator ring we custom fabricated.
    https://www.facebook.com/89165005420...type=3&theater
    Alliston, Ontario, Canada
    I have used my horn exactly zero times in 8000km of driving. I wouldn’t worry about it.
    2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
  7. Likes Joel Hauser liked this post
    Colorado Springs
    Quote Originally Posted by Murd View Post
    Giving your finger a lot of exercise?
    .boB "Iron Man"
