https://thefactoryfiveforum.com/show...l=1#post212968
I'm at the step where I'm getting my Boyd Tank setup to install, and found the link above about the larger check valve/vent to ease filling. This seems like a no-brainer upgrade right now because this is something that could cause frustration at each fillup. The Breeze valve is larger https://www.breezeautomotive.com/sho...eck-valve-kit/ but it's setup for the push-in type setup
I'm still getting used to NPT fittings, the FFR valve ranges from .83" wide at top to .75" at bottom
the Boyd Tank has an NPT fitting that the stock FFR part fits, but are there larger aftermarket ones?
