Likes Likes:  2
Results 1 to 4 of 4
Thread: has anyone adapted a Ford Easy Fuel cap to the Aston LeMans Style Cap?
    Folsom, CA
    Question has anyone adapted a Ford Easy Fuel cap to the Aston LeMans Style Cap?
    FFR gives you a modern vacuum cap that is concealed inside the polished aluminum exterior of the LeMans Cap
    http://www.factoryfiveparts.com/1474...emans-gas-cap/
    can a passthru cap be used instead of a twist on/off?
    Todd
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I had one like this: https://www.speedwaymotors.com/Hagan...iABEgJbVfD_BwE on our MK-II for a bit. Had some issues with it not allowing the gas nozzle to auto-shutoff and got a lot of back-splash when I pulled the nozzle out of the filler. Went back to the standard "manual" style cap and haven't had a problem since.
    But as they say......"Your mileage may vary."
    Ray
  3. Likes toadster liked this post
    Junior Member s_martin's Avatar
    Bozeman, MT
    I got the same thing from Breeze.
    https://www.breezeautomotive.com/sho...rough-gas-cap/
    There is still snow on the ground here so I haven't actually used it yet, but I like the idea. It fits under the LeMans cap on my MKII with no interference.
  5. Likes toadster liked this post
  6. #4
    Hamilton, VA
    Quote Originally Posted by s_martin View Post
    The Breeze cap works great!
