Results 1 to 5 of 5
Thread: Parking brack won't release on left wheel
    Mar 2018
    Saint Johns, Florida
    Question Parking brack won't release on left wheel
    Hello all,
    Here I am again. Got the driveshaft to adapter bolt situation fixed. However, for a long time the left rear brake caliper has been sticking after using the parking brake. The little coli spring seems not strong enough to pull the cable back. I tried re-routing the cable to avoid tight bends but still the brake sticks and I have to pry the return spring.up to release the parking brake. Maybe need a new cable. Or...is there a stronger spring to overcome the friction of the cable?
    Hope to hear soon,
    Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
    vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
    Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
    Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
    try removing the cable and see if it still does it. If it does you might need a new caliper. If it doesn't you need to reroute your cables or find a place to attach a return spring to that caliper.
    Dec 2017
    I put a piano spring in there to pull it back. Can't take credit for the idea, but works great!
  4. Likes Aircontroller liked this post
    Mar 2018
    Thanks, I was thinking about such a spring. Re-routing didn't work.
    I wonder if this was the same cause for the sticking?
    https://thefactoryfiveforum.com/show...tiple-calipers
