Likes Likes:  3
Results 1 to 8 of 8
Thread: eastwood brake flaring tool on backorder!
    Folsom, CA
    Unhappy eastwood brake flaring tool on backorder!
    in advance of getting the car, I opted to order the Eastwood brake flare tool because of the reviews, and figured I may as well do it once and do it right!
    I ordered it over the holiday special for $179, depending on the time of year that can be up to $50 off!
    bad thing is, my order says Backordered 2020-03-04 !!!
    just in case anyone was looking to get one quickly... it's gonna be a while!
    Todd
    Jan 2019
    Detroit MI
    It will be well worth the wait. It makes perfect flares and in 1/5 the time it takes to do it the old way.
  3. Likes toadster liked this post
    Alliston, Ontario, Canada
    I’m sure someone else sells it that has one?
    2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
  5. Likes toadster liked this post
  6. #4
    I bought mine from Jegs -- on sale right now for $180.00 and at least ten on hand.
    https://www.jegs.com/i/JEGS/555/80883/10002/-1
  7. #5
    Folsom, CA
    yeah, I guess same part available from other vendors...
    even Amazon has it
    is the 37 degree head available elsewhere as well? for AN fittings?
    Todd
  8. #6
    I bought a TGR set from Amazon. Its an amazing set, ive used the 45 and 37 degree dies (came in the kit) and never had a single bad flare. Totally recommend it.
  9. #7
    Mar 2013
    Medway, MA
    Has anyone ever tried the Earles 3/16" Double Flaring Tool?
    https://www.breezeautomotive.com/sho...ke-line-earls/
  10. #8
    Dec 2018
    Hudsonville, MI
    X 2 on the TGR labeled version.
    Coupe Kit Delivered 11/10/23
  11. Likes toadster liked this post
