Results 1 to 3 of 3
Thread: coupe - race or street steering rack holes
    Aug 2019
    We are building a car for 80% street use, but I like a very small gap between tire and fender.
    If using the bolt holes on steering rack for "street" - can you adjust the suspension down to a pretty small tire/fender gap?
    I'm assuming that 'race' is too low and results in a lot of scraping the frame on driveways and such- is that correct?
    Any comments on what you folks have done out there?
    Note: running the power steering system w/steering rack from "complete kit" set up and 18" wheels.
    Edmonton Alberta
    use the street locations. The ride height can easily still be low, just under 4 inches on mine.
    David W
    Mkll 4874 built in 2004
    Aug 2019
    Sounds good - thanks David!
    David W
