Hello Everyone. Having a weird issue and wondering if anyone else may have experienced it before. 1963 Ford Fairlane with a 2017 Coyote and Edelbrock TVS-2650 Supercharger. Stock throttle body. PMAS air intake (have tried others). 95lb fuel injectors. Aeromotive in tank pump. Long tube headers. 6R80 auto. LUND has been remote tuning (or attempting to). FRPP w/ SCT . Cranks fine. At idle 43lb fuel press with vac line, 55 without. Never drops even when reving engine. At idle the log varies, showing a 30% - 70% fuel correction. Run it to 2000 rpm and little correction, sometimes pulling fuel out. Did a leak test and found nothing. Did a compression test and all good. No matter how much fuel added through the tune it shows it needs more. Plugs look pretty good, maybe a bit on the lean side.
