Be sure to set your drive line angle before you do any cutting on the exhaust. I used a GM transmission mount from Summit and had to shim it about 1 1/4 inches (aluminum 1/4" shims) to achieve the proper angle.
Yes I just checked and the angle is the wrong way (UP). So you have the mounting plate that attaches to the frame in the "U" position. Then added the inch and a quarter of shims?
My mounting plate is in the "n" position and I know I need to change it.
What is the distance between the floor and the bottom of the transmission tail shaft? I need a good reference. Thanks for your suggestion.
