I would like to know what kind and type of insulation is being used on the interior of each foot box and how many square feet did you use?
I used two boxes of Dynamat (https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1) to insulate the entire trunk & cockpit.
The adhesive is REALLY sticky. I recommend putting the Dynamat on the inside of the foot box panels before you permanently install them.
MK IV Roadster #8631
Reflectix double sided attic insulation. Did not keep track of amount. Very inexpensive at Home Depot.
Installed outer foot box sides after insulation & carpet was installed. Used 3M 90 spray adhesive.
Kevin
MKIV #8234
NITTO NT01 275X40XZR17 - 315X35ZRX17
I used TheroTec Cool Mat on the entire inside of my cockpit. It took five 3x5' rolls. I didn't do the trunk.
My Coupe Build Thread: https://thefactoryfiveforum.com/show...65-Coupe-Build
My Roadster Build Thread: http://thefactoryfiveforum.com/showt...ter-Build-9754
Member of the The Gateway Cobra Club
I am thinking about trying this stuff. It's called Aerogel. You have probably seen it demonstrated; a guy holds a small piece in his hand and then hits it with a blow torch. Anyone used it yet? How did it work?
https://www.amazon.com/dp/B07HFZHTRL...0-a9f4b3ebd6b4
Its like filling a glass. Once it gets to the top its full. Most if not all of the currently used insulations will keep engine heat out if you seal all the leaks. 99% of the interior heat will then come from the sun.
Kevin
MKIV #8234
What do ya'll think about the Summit Brand Heat & Sound Barrier?
https://www.summitracing.com/parts/sum-879006/overview/
Do you think it would be up to snuff or not?
I like Second Skin Audio and use it on all my customers builds and mine. Not cheap ~$350 but well worth it and easy to apply. I use the Damplifer Pro and do apply it to trunk and all interior aluminum and also put a piece inside the doors to give them a much more solid feel and sound.
Henry
I only have 2 summers on my car so far.. but.. they are South Texas summers!
Similar to BEAR...
I put in a layer of Stuff I got from Amazon. It was called EZ Cool Vehicle Insulation. I think it cost me about $35 for 10' of the stuff.
Amazon doesn't seem to have it any more.. but.. it was exactly like this stuff.
https://www.amazon.com/Car-Insulatio.../dp/B016QUS1YE
Used some 3m spray contact glue.
I ONLY put it on the firewall and Inside both foot-boxes.
I even put it on the bottom of the foot box, but it gets packed down hard under my loud-pedal foot.
Nothing added to the top of my trans tunnel.
That said.. I can detect no additional heat coming through the panels. Even before I added the carpet, I could put my hands on the surface of the stuff, and feel nothing after a long hard drive.
I could feel a small amount of heat through the aluminum on the trans tunnel.. but.. now that I have it carpeted.. I feel nothing at all.
I don't know it would have been a waste to put some on the trans tunnel too.. but.. I don't know it would have mattered either.
2016 MK4 | '99 Explorer 5.0 | E303&600cfm carb | T5z + 3.55 | 3-link | SN95 | PB/PS | FR500 17" 315&275 |
I just carpeted the cockpit and wear earplugs. Done!
Papa liked this post
I used one called hushmat I saw recommended on here by one of the pro builders. When I researched it it seemed to have better heat resistance where most of the other similar products were more about just sound deadening.
I used 2 boxes (70 sq. Ft. total) of X-Mat from Eastwood. Excellent stuff, adheres well. I did my complete cockpit, firewall and trunk floor with the two boxes with only a few scraps left.
MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
Another vote for ThermoTec Cool Mat. It's easy to use and seems to work pretty well. I think I used four rolls.
