This last week was a bit of a learning experience.
The transmission mount ended up that I will ask FFR for the plate for the transmission I have. That should take care of that. I did receive the Lokar shifter. I have to determine the final position after the seat is in place. Then I will cut the shifting rod and make the final adjustment.
The brakes are finally bleed. My son came over and helped. It turned out to be air in the line. The peddle starts soft but doesn't go to the floor as before. Final adjustment when I go-cart later next month.
I did get a partial shipment from FFR this week. The trans. mount came with a copy of the new manual and a few brackets and cables. Still waiting for my front springs and steering wheel.
I wanted to have the fuel lines run by now but the trans. mount and brakes set me behind. I will get them done this week. In talking with my son I changed how I was going to route them. I have the meters are temporally placed on a board along with the switches. Getting ready for the first start.
So here are a couple of pictures 100_2183.JPG 100_2184.JPG. You won't see much of a difference as most of the changes are adjustments and small things that have to be done.
Cliff
'33 Hot Rod Chassis #1118, Gen 2, hard top, bike fenders, AC, electric steering. BluePrint Engines Chevy 383 Fuel Injected with the 700R4 transmission 8.8" rear 3.55.
