Results 1 to 10 of 10
Thread: Motor position
    Oct 2018
    Motor position
    OK guys need some help from the pros. Installing a small block Ford from blue print engines in my roadster with a T5 Transmission. I think I have the motor mounts on correctly driver's side the boss is below the stud and on the driver's side the boss is behind the stud. The problem is the engine seems too far back and low. One of the bell housing bosses from this starter is touching the diagonal brace. The starter itself is resting on the four inch tube and will not bolt up. And the drive shaft when fully engaged only has about 1/8 of ainch to the rear when the wheels are at ride height. Can anybody offer any suggestions?20190508_194710.jpg20190508_194656.jpg20190508_194739.jpg20190508_194717.jpg15573608166632185840191318255823.jpg15573609240201543785168332397576.jpg
    Mar 2015
    AZ
    I believe the drive line is set to the passenger side 2" to compensate for the driver's weight. How do you have the transmission set on the bracket in the back?
    Oct 2018
    I have about 1 1/2 slot length that I can move forward
    That starter is wrong. Is it clockable? The solenoid should be at the top, not on the side.
    Perth, Australia
    The drive line is actually 1" of centre. I did measure it.
    Tim
    FFR MkIV #7393 - LS3, TR6060, 8.8" - Registered 2015 - Painted 2019
    HSV Clubsport R8
    Kwaka ZX-14R
    Oct 2018
    Jeeze I must have been tired. Yes it is clockable thanks
    have you shimmed the trans mount yet? Quite a few end up w/ 3/4 in of shim to get the drive shaft angles correct. Search for pinion angle threads for more info.
    Oct 2018
    I have not done anything with Trans shims yet
    Jax Beach, FL
    I agree, clock the starter and shim the transmission up. The starter picture looks you have the transmission pretty low.
    Oct 2018
    Thanks guys clocked the starter and solved the problem
