Results 1 to 6 of 6
Thread: Serpentine Belt Routing Question (including P/S)
    Portland, OR
    I am going with power steering in my 302 setup.
    What belt routing applies in this case? I'm guessing one of these two? and I will need to acquire the A/C delete mounting hardware, yes?
    Blue Oval Scribe
    Lakeland, FL
    I presume you are keeping the stock pulleys/brackets in your build? If so, then yes, you'll need the Ford Racing A/C delete or an aftermarket equivelant to mount the P/S on the driver's upper where the A/C used to be. Reason being, the p/s in the stock location is too low for the belt from the alt to reach the p/s, as it would rub the top of the water pump pulley and make the stock tensioner inefective.
    I don't know what your budget is, but there are several bracket kits out there that will seriously clean up the front of your engine by getting rid of all of the stock cast brackets. March, Summit Racing, Forte, Breeze, etc. all have various brackets in aluminum or steel.
    HTH...
    Mark
    Modified Mustangs & Fords Project Snake Charmer
    FFR5310 Mk 3 Roadster
    Tungsten Gray/Silver Stripes
    Portland, OR
    Quote Originally Posted by Mustang Man View Post
    Wow : looking at the offering from March, I am blown away. Looks gorgeous! Thanks Mark.
    Forte's Parts Connection
    snakeboost's Avatar
    Framingham Ma on a computer
    Yes the March is purty but $$$$$ might look at ours for le$$. Alternator / power steering / & pulleys = $360.00
    Forte's Parts Connection: Your Solution Specialist! Motor & Transmission Packages Starting @ $8200.00 Call To Order 508-875-0016
    Paht time parts guy!!!!!!!
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    I would go with option 1 get as much wrap on the alt as you can - also after all the belts I have been through I recommend the Goodyear gaterback belts! harder to find not sure why but the tend not to stretch and they grip better - just a personal opinion.
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
    Here is what I got for my 302 from March....you would just get the same kit but with a P/S pulley instead of an Idle Pulley...this shows the same belt routing as your first pic.
