Thanks Thanks:  11
Likes Likes:  18
Page 21 of 23 FirstFirst ... 111920212223 LastLast
Results 801 to 840 of 884
Thread: My Official GTM Build Thread!
  1. #801
    San Diego
    Have you thought about just keeping your dashes bespoke for whatever the customer needs? Case in point is that I know a guy here local that does custom car work. Not your normal stuff, but some serious stuff where MLB players will go and buy a McLaren and drive it over from the lot and ask him to gut the interior and "make it their own". He only does high end stuff. I think your product would fit into this market nicely, and you could likely charge 60% MORE than the other guys, and these people would pay it to have something that no one else has. If you are interested, let me know and I will put you in touch with this shop. They do some amazing work.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  2. #802
    LCD Gauges's Avatar
    Toronto, Ontario
    Thanks Shane, I appreciate the quick response. I'll likely use the Vette hose for now, then replace it with a chrome neck later.
    Mike,
    By "Bespoke", do you mean 'custom' or "exclusive"?
    At the moment every kit that I've sold has been customized graphically and even to adapt 3rd party hardware (ie: HVAC or lift systems).
    I'm not opposed to designing exclusive graphics for people. My current graphic capability could not compete with OEM supercars.
    I have already priced out the software at $40,000 USD + license fee per unit. I can't do that right now.
    Thanks for the offer to refer me. I'll keep it in mind once I have updated the hardware and found a better graphics solution.
    www.LCDdash.com \\ info@LCDdash.com
  3. #803
    Jul 2014
    Hey Tino,
    The 90 degree elbows you are talking about are something like the Spectre Performance 7898 Magna-kool Radiator Hose End Cover. I'm not sure if this is the exact model number, as I only came across the name brand one day and jotted down the note to go back later and get the proper one, but here is a link
    https://www.ebay.com/itm/Spectre-789...lag1MW&vxp=mtr
    BTW very cool news about getting some of your stuff shown at SEMA!!!!
  4. #804
    San Diego
    www.myraceshop.com
    GTM solution kits
  5. Likes Aircontroller liked this post
  6. #805
    Indiana
    What are the thoughts on rubber vs silicone vs aluminum vs steel/chrome radiator tubing? Are all adequate?
    GTM #304 LPE 525hp LS3
  7. #806
    San Diego
    I personally would stick with silicone and aluminum, although we do have some steel on the race car. Not a fan of the corrugated hoses and tubes. They tend to adversely effect flow. They may be convenient, but you will never see one on a car I am involved with.
    www.myraceshop.com
    GTM solution kits
  8. #807
    LCD Gauges's Avatar
    Toronto, Ontario
    Thanks for the tips guys. I'll tackle a temp solution over the weekend as this car has to go by end of the month!
  9. #808
    Indiana
    Has to go where?? Are you selling it?
  10. #809
    LCD Gauges's Avatar
    Toronto, Ontario
    Noooooooo...moving (again)!
  11. #810
    LCD Gauges's Avatar
    Toronto, Ontario
    We're finally settled into this temporary, rental house until our home is ready. On that note,
    if any of you have done this to your cooling system, or you're thinking of doing it - just stop.
    Stop it now!
    The previous owner simply slid this hose into a rubber sleeve and hoped that the epoxy would
    do the trick.
    Luckily I was in the driveway doing the initial "run-up check" for the first drive of the season
    when it popped.
    Thanks to everyone for their links to the chrome piece.
  12. #811
    LCD Gauges's Avatar
    Toronto, Ontario
    Today I'm going to switch hats from,"LCD Business Tino" back to, "Building a kit-car Tino". I miss getting my hands dirty and working in the garage...
    and just being an F5R forum dude!
    After many years of sitting on this project, I'm biting down and making time for myself and the GTM. Job #1 is getting my own LCD gauges installed.
    It's a crime that I'm not able to demo the system, or provide a decent photo of the interior when people ask. Today I spent the afternoon gutting the
    interior.
    The entire dash has been removed, seats pulled out, and steering column (again). The sloppy play in the linkage needs to get fixed. I know I'm
    missing a bearing, or sleeve in the telescopic portion of the column. There is also a requirement for a secondary bracket and flange bearing to
    prevent the universal joint from binding when the steering wheel is turning.
    Now that I'm in the footwell area, the openings in the firewall can be addressed. If you haven't looked close enough, or used some backlighting, you
    may not notice all of the air leaks. Most obvious is above the pedal box - I'd like to make a cover to keep the rad heat from getting into the cabin.
    I'm having someone redo the gauge pod, and will be replacing the vinyl with Carbon Fiber (same for the passenger side cover). I think a matte finish
    will be best to reduce sun glare. The contour of the pod is also going to change from a rounded hood, to a flat top with radiused corners to fit a 12.1"
    LCD screen.
    The stereo has been pulled and will be replaced with a touchscreen controller/media player with all the options to use as a demo at car shows and future
    trade shows. Plus, you can't beat the cool factor of an electronic engine start/stop on screen!
    In other news, I met Murray Pfaff while doing a tradeshow in Toronto. Funny guy, and remembered recommending my system to a customer of his.
    I thanked him for hooking me up, and he said he'd look me up from time-to-time. We shook hands, exchanged business cards, and off we went.
    Kinda cool to finally meet him after seeing so much of his work!
    Look at me writing about business...
    Anyway, I'll update again once the new dash pod is shaped. Right now, the guy is laying down the fiberglass to make a mold/copy of the original and
    then we're going to modify the copy ( I have no idea how this stuff works)!
  13. Thanks Aircontroller thanked for this post
  14. #812
    Caldwell (near Boise) Idaho
    Tino. I don't know if your steering wheel flexes too much on it's mounts but this is how I stiffened mine. 4 bolts vs 2 and moved the wheel closer to the dash compensating for the space out caused by the quick release steering hub.
  15. Thanks LCD Gauges thanked for this post
  16. #813
    LCD Gauges's Avatar
    Toronto, Ontario
    Good idea! More mounting points will certainly help the total column flex.
    The issue with mine is more with the shaft play, and binding when turning the wheel. The U-Joint tends to "walk up" at a certain
    degree and cause a bit of a jolt. If I can mount a bearing just before the u-joint, it will eliminate the nuisance as well.
  17. #814
    LCD Gauges's Avatar
    Toronto, Ontario
    The pod re-work is moving along. Saturday we'll be fitting the screen and making the new
    contour for the dash. I can't wait to finally hit the button and see the gauges come alive!
  18. #815
    Jul 2014
    Thats going to be pretty slick!!!
  19. #816
    Indiana
    Yeah, I would love to have a massive display like that!
  20. #817
    Newcastle, Wyoming
    Will be different cant wait to see the finished project might have one of these systems on my next build
  21. Likes LCD Gauges liked this post
  22. #818
    LCD Gauges's Avatar
    Toronto, Ontario
    Getting a bit closer to the LCD install. Theo (the CF/Fiberglass guy) is coming over in a few days to grab the wooden template so he can
    shape the pod. Once that's done and the test fit is done, it's getting sent for Carbon skinning! He talked me into redoing the entire interior
    as well. Everything vinyl will be covered with CF, and the dash items will be 'flat' to prevent glare.
    I'm a few days away from wiring the system, but I had to edit some images to get an idea of aspect ratio. I'm not sure which skin I'm going
    to use, but I really like the tachometer in this layout.
    While that's setup, pappa is doing up a wicked looking skin that is based on a video game. A bit of a teaser...
    For anyone doing fiberglass molds, check out this pink spray-on release agent. It just peels off, and literally
    no resistance to separate the parts.
    Next post I'm hoping to have a video of the actual gauges working with engine running!
  23. #819
    Jul 2014
    That is going to be very nice when you get it all together.
    What's the brand of the release agent you mentioned?
  24. #820
    Quote Originally Posted by Shoeless View Post
    Looks similar to the stuff I use but it's green....Partall film#10
    Shane Vacek
    www.vraptorspeedworks.com
  25. #821
    San Diego
    Quote Originally Posted by VRaptor SpeedWorks, LLC View Post
    That's the same stuff I use.
    www.myraceshop.com
    GTM solution kits
  26. #822
    Perfect spray gun for application...these are on sale all the time at Harbor Freight for $9.99 and do a perfect job with the Partall film#10:
    Shane Vacek
  27. Likes LCD Gauges liked this post
  28. #823
    Jul 2014
    Thanks for the heads up guys.
  29. #824
    LCD Gauges's Avatar
    Toronto, Ontario
    I've been trying to get the info about the release agent from "my guy", but he hasn't been very responsive. Oh well, I hope he is still moving along with
    the fiberglass work!
    The new skin for my car is complete. It's a bit 'off the wall', but I like it! I'm uploading it to the system and will be wiring it up this week.
    This will be for the console touchscreen:
    I finally got smart and installed a one-way fuel valve. Now I can use the system to prime the fuel rail and shut off the pump
    with the pressure reads 55 PSI. It will make starting the engine a bit easier I suppose!
  30. #825
    Indiana
    That looks great!
    I don't remember if you mentioned it - are you running navigation and audio through your system?
  31. #826
    LCD Gauges's Avatar
    Toronto, Ontario
    Thanks! Yes, it will have NAV/GPS and a media player with FM radio as well.
  32. #827
    LCD Gauges's Avatar
    Toronto, Ontario
    Mid June and this car will not see the finish line again this year. The dash work that started in April still isn't complete - you just can't pay enough for speedy
    work it seems. :/
    I can't say I'm disappointed in the progress however, the new interior is going to look great. I'm planning to redo the console and skin the waterfall, as well as the passenger cover in Carbon Fiber.
    7 years and counting. I've torn out the inside for the 3rd time. I'm ripping out most of the electrical that was installed when I purchased the used kit. Ideally, I want to
    lift the body and start over, but there's no time for that! Maybe over the Winter months if the schedule allows. Anything goes before the body is completed for
    paint I guess?
    The new contour of the dash pod is going to look great with the LCD. The added glare-shield looks a bit more OEM I suppose.
    Hopefully it does the job.
    Last but not least, the gauge skin is still getting tweaked. I'm always messing with it! It will probably go through
    another major change before I'm happy with it.
    I've got some exciting news for the LCD Systems as well - I've contacted a few magazines, and have redone my
    website. More to come in their own dedicated thread.
  33. Likes Edgeman liked this post
  34. #828
    LCD Gauges's Avatar
    Toronto, Ontario
    I've been fighting the urge to post a video of the LCD gauges, but I need to wait for the final Carbon Fiber part to arrive.
    The mould is complete; this is just painted fiberglass. We're hoping to have the final product here by month end (or sooner!).
  35. Likes Edgeman, rolfer liked this post
  36. #829
    LCD Gauges's Avatar
    Toronto, Ontario
    I received the first cut from the mould. It's pretty good, but needs some tweaking. By mid July, I'm hoping to have the final CF part and
    ready to lock in the LCD gauges!
  37. #830
    LCD Gauges's Avatar
    Toronto, Ontario
    Such a slow process, but I'm busy doing other stuff so I can't be too upset. He says there is one more
    clear coat to add, then it's done. I can't wait to get this stuff in the car already!
    Attachment 111739Attachment 111740
    I'm also getting this skin completed for the big debut:
    Attachment 111742Attachment 111743Attachment 111744
    A shout out to my graphic's guy Kyle, who is doing some killer word on skin designs!
    He's the boss with all of his cool software and keen eye.
    Attachment 111746 Attachment 111745Attachment 111741
  38. Likes Edgeman liked this post
  39. #831
    LCD Gauges's Avatar
    Toronto, Ontario
    We're moving at a snail's pace with this interior work. It looks amazing, but waiting is killing me. I'll have to move forward with my demo
    video using an alternative pod in the GTM.
    Some cool looking graphic software for a new project coming up!
  40. Likes Edgeman liked this post
  41. #832
    LCD Gauges's Avatar
    Toronto, Ontario
    Getting somewhere with this interior (finally!). The Carbon Fiber is just beautiful; the vinyl can no longer stay! Over the Winter I'm
    hoping to have the doors skinned with CF and the remainder of the console covered with a flat CF.
    The gauges are alive, but not yet connected to the sensors. I'll be digging away all week to get a functional video of this thing in action.
    Sorry about the blacked out squares, there are just too many eye-sores happening with wires and unfinished interior.
    The new pod fits very nicely. It's not screwed down yet, but the contour matches well.
    The Double DIN is roughed-in. I'll need a 90 degree adapter to get more clearance for cable in the rear,
    then it will sit flush with the console. The LCD is a live shot, but there's no bezel over the display yet.
    I'm trying to find the best method to cut Carbon Fiber straight and clean.
    This is a little photo edit of how it will look with trimmed and finished.
    P.S. This pod and trim plate is for sale (Carbon or Fiberglass). Message me if interested. A proper thread will be posted later this week!
  42. #833
    San Diego
    Regular saw blades in an air saw can be used to cut fiberglass and CF but they wear out quickly. I found some carbide blades at Home Depot that last a LONG time. They are used for cutting ceramics. They have little bits of carbide fused to the blade. This still is just a rough cut and an air sander or file can be used to straighten all the rough cuts. It's definitely a process.
    www.myraceshop.com
    GTM solution kits
  43. Thanks LCD Gauges thanked for this post
  44. #834
    I just checked out their website and I see lots of different carbide blades for jigsaws and sawzalls, but I don't see any that look like they're specifically for a small body saw? I'd definitely be interested in what you're using as none of the body saw blades I've used will hold up to very much use on fg and especially cf.....
    Shane Vacek
  45. Thanks LCD Gauges thanked for this post
  46. #835
    San Diego
    I'll see if I can get a picture and post it. I did have to modify the mounting tang to fit my air saw by grinding it slightly IIRC. Hopefully I still have one in a package. To give you an idea, I cut the GTM body into over 20 pieces with LONG cuts along the lengths of fenders, etc. I never wore out the first blade doing this.
    www.myraceshop.com
    GTM solution kits
  47. #836
    Indiana
    I agree. As good as the new 3D carbon fiber vinyl overlays look, I'm a big fan of sending a DXF file of the gauge surround to Shane at Vraptor, have him cut it from aluminum (with perfectly straight lines, arcs, circles, symmetry, etc), then take that exact same DXF to the wife's Cricut and cut (with perfectly straight lines, arcs, circles, symmetry, etc) the pattern from CF vinyl and lay it on the aluminum.
    I don't know anyone who would bet me $1000 that this isn't real CF:
  48. #837
    Very Nice!.....and my daughter has a Cricut......never thought of using it for that!....I did consider having her make some vinyl company decals for me, but never thought of using it to cut the vinyl to fit the parts!
    Shane Vacek
  49. #838
    LCD Gauges's Avatar
    Toronto, Ontario
    I have a tile cutter that would definitely help with straight cuts.
    I'm pretty sure it would prevent fraying/chipping, but I'll test it on some scrap pieces first.
    Anyone against this with certainty, or do I have a good shot?!
  50. #839
    LCD Gauges's Avatar
    Toronto, Ontario
    Finally, some functions connected and working.
    Much more to go, but it's alive and well.
  51. #840
    San Diego
    Here is the one I was talking about and use regularly...
    www.myraceshop.com
    GTM solution kits
  52. Thanks LCD Gauges thanked for this post
