I am going with power steering in my 302 setup.
What belt routing applies in this case? I'm guessing one of these two? and I will need to acquire the A/C delete mounting hardware, yes?
I presume you are keeping the stock pulleys/brackets in your build? If so, then yes, you'll need the Ford Racing A/C delete or an aftermarket equivelant to mount the P/S on the driver's upper where the A/C used to be. Reason being, the p/s in the stock location is too low for the belt from the alt to reach the p/s, as it would rub the top of the water pump pulley and make the stock tensioner inefective.
I don't know what your budget is, but there are several bracket kits out there that will seriously clean up the front of your engine by getting rid of all of the stock cast brackets. March, Summit Racing, Forte, Breeze, etc. all have various brackets in aluminum or steel.
HTH...
Mark
Modified Mustangs & Fords Project Snake Charmer
FFR5310 Mk 3 Roadster
Tungsten Gray/Silver Stripes
Wow : looking at the offering from March, I am blown away. Looks gorgeous! Thanks Mark.
Yes the March is purty but $$$$$ might look at ours for le$$. Alternator / power steering / & pulleys = $360.00
Forte's Parts Connection: Your Solution Specialist! Motor & Transmission Packages Starting @ $8200.00 Call To Order 508-875-0016
Paht time parts guy!!!!!!!
I would go with option 1 get as much wrap on the alt as you can - also after all the belts I have been through I recommend the Goodyear gaterback belts! harder to find not sure why but the tend not to stretch and they grip better - just a personal opinion.
Ralph Button
FFR 1436 (PROUD Owner of an Original Mark I)
400,013 miles as of 11/1/2009
417,840 miles as of 8/12/2010
435,021 miles as of 12/19/2011
Now a well broken in 347 engine
523,145 miles as of 7/29/2014
601,165 miles as of 6/1/2018
615,215 miles as of 4/23/2022
"It's not about the destination, it's the about the journey. And where is your journey taking you?"
"... Not all who wander are lost!... --J.R.R. Tolkien
Here is what I got for my 302 from March....you would just get the same kit but with a P/S pulley instead of an Idle Pulley...this shows the same belt routing as your first pic.
