Results 1 to 24 of 24
Thread: Chrome vs Stainless vs Ceramic headers : which is better?
    Portland, OR
    Looking at Jegs, LMR & eBay for some shorty headers for my 302 roadster build.
    Heard that stainless is better for rust resistance and strength whereas ceramic coated is better for heat dissipation and better fitment. Chrome just looks good but is the worst choice.
    My opinion : go with stainless.
    What do you use & recommend?
    CHROME BBK-1515 $189
    STAINLESS TopStreetKing $79
    CERAMIC BBK-15150 $299
    Houston, TX
    I have all three:
    Chrome will develop rust (my brand new heat shields have rust spots all over them already).
    My sidepipes are stainless and they have already started to turn brown/blue due to heat.
    My headers are ceramic coated and look exactly the same as they day they arrived.
    YMMV
    HTH
    Todd
    A better question to ask might be "What brand fits?" Remember these get turned around backwards and when doing so some shorties have issues with contacting motor mounts and such. I used 4 into 4s on both builds so can't advise on specific shorty brands but want you to know that they aren't all created equal when it comes to fit & clearance. After you know what will work then you'll know what your choices of finish are (personally, I'm not much for bling and would use ceramic but that's just me ).
    Good luck,
    Portland, OR
    Quote Originally Posted by tjmotter View Post
    I have all three:
    What brand & model did you buy for the ceramic headers and did you have any fitment issues in reverse position?
    Stainless rocks... Yes it turns but doesn't chip or rust.
    FFR 7216 MK 4 Non Donor Street Legal 06/13/11 at 4:30 pm! Graduation 1/1/2012
    3 Link Ford Racing 3.73 8.8 Posi with Yukon Axles.
    4 wheel discs Brembo rotors and Hawk HP plus pads.
    Ford Racing 302 340 HP T5Z 5 Speed Stainless Headers and Side Pipes.
    Holley 670 Street Avenger on Edelbrock Performer RPM. MSD Pro-Billet Distributor
    Delivered 04/11/10 7:30 pm Roller 05/08/10 Engine installed 08/07/10 First Start 02/19/11
    ceramic coat, no question - I can drive for 30minutes, stop, and touch my pipes and not get burnt.
    I've stood by people's cars who've chromed or powdercoated them and could feel the heat radiating off them when I'm 8feet away.
    Too many to count
    Houston, TX
    The headers came from FFR (BBK I believe). Note that I have the 4 into 4 big pipes (not the shorty's).
    Quote Originally Posted by jakester888 View Post
    Brookeville, Maryland
    I've got the ceramic BBK's on mine and they clean up nice. Got some ceramic header cleaner from JEGS. I had the sidepipes done in late winter and so far so good. They are done the same as the headers and j pipe, ceramic chrome silver.
    Stoneville NC
    Ceramic will stay looking the same for way longer. I would do ceramic headers and stainless side pipes, but if you are going with shorties, you may have to go with chrome side pipes .
    Al Adkins
    Certified "Kool Aid" drinker
    Stoneville NC
    That must be a type.. I doubt if you can get a stainless shortie for 79 dollar
    Also, look at the flanges.. something looks funny about the street kings... looks like the bolts will be a pain to get on and off. Look at how the others have rectangle tubing where it mates with the flanges. Much easier to work with
    Al Adkins
    Sep 2011
    I have owned JBA, BBK, MAC and more. FRPP stainless shorty are the best for the $$, more $$ yes but the best fitment. JBA are nice too but $$. Same with Bassani. BBK ceramic are ok, but I'd get FRPP 1st. PLUS the design of the FRPP makes header bolt install easier.
    The Ford Racing shorties may work well in Mustangs but have one of the worst reputations for fit when reversed for use in our cars. Here are two of many discussions regarding fitment issues:
    http://www.ffcars.com/forums/17-fact...t-fitting.html
    http://www.ffcars.com/forums/17-fact...-question.html
    Portland, OR
    I went with BBK ceramic shorties.
    Thanks for the tips guys.
    Colorado Springs
    Performance wise, ceramic is best. A good header will pull the exhaust gasses out of the chamber by created sort of a negative pressure zone. That negative pressure zone depends a hot exhaust pulse in the collecter from the other pipes. The hotter the pulse, the greater the efficiency.
    Ceramic heat barriers keep that heat inside the pipes, and should increase efficiency, which should increase power. That's the theory, anyway.
    Also, by keeping the heat inside the pipe, that should help decrease under hood temps.
    A good ceramic coating is done on both sides of the metal. In theory it is a solid coating with no breaks or cracks. That keeps a lot of the heat and all of the moisture off of the base metal. It should last a lot longer than bare steel.
    People use SS and chrome simply for looks. Of the two, I think SS is the better choice. Chrome expands and contracts at a differant rate than the base metal. Eventually, the chrome will crack, and seperate from the pipe. That allows water and air to contact the base metal, and rust will develop. But, considering that most people drive their Roadsters <5K miles a year, that's probably not much of a problem.
    The side pipes are another deal altogether. Ceramic coating retains the heat inside the muffler and pipes. That's not exactly a good thing. SInce all that heat is in constant contact wih the muffler materials, they may not last as long (again that 5K miles a year may make this a moot point). Ideally, you would want the gasses in the side pipes behind the collecter to cool rapidly. As the gasses cool, they contract, and are easier to expel. In theory.
    .boB "Iron Man"
    NASA Rocky Mountain, TTU #42, HPDE Instructor - Retired 10/24
    www.RacingTheExocet.com
    Stoneville NC
    Don't think for one minute that you won't leave some meat on the ceramic pipe if you touch it... It is cooler.. but you can still get that fresh cooked bacon smell if you lay a leg on it.
    Al Adkins
    Quote Originally Posted by Raceral View Post
    Disagree.
    I can drive my car for 30minutes, oil temps 200, water temps 190, stop, get out, and touch the pipes. Heck, I even hold my hand on them for several seconds w/o fear.
    Once I even started playing w/ my air filter after a drive, completely forgetting my leg was touching the 4into4 headers exiting the body .... with my leg touching them it took me like 4 or 5 seconds to even realize it, and no burn mark or anything.
    I don't have a super secret ceramic coating or anything on it; just regular jet hot coating done on the inside and out.
    Too many to count
    ceramic chrome
    Hi
    use mothers mag & aluminum polish on ceramic chrome to keep your headers or side pipes in new condition we find it works the best
    Junior Member Quatro007's Avatar
    San Diego, CA
    Quote Originally Posted by efnfast View Post
    Disagree.
    Interesting! I have the Jet Hot coating as well and a few people have gotten snake bit on them and that was on the tip. You can however slap them and not get burned. The only coating I've ever experienced being able to directly touch and not get burned was fiberglass header wrap.
    Fort Lauderdale Fl.
    My ceramic chrome will cook you sure as a stanless.
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    A split second against ceramic at the collector:
    It was kinda' cool that it really did sizzle like bacon (well, before the pain started that is)
    Dallas, TX
    There do seem to be differences in ceramic coatings, so if you go the ceramic coating route do your homework.
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
    Quote Originally Posted by Quatro007 View Post
    Was it done on the inside and outside?
    Too many to count
    Lineboro MD
    I went with the ceramic headers for the reduced under hood temps and the stainless side pipes for the polished look. It will better match my stainless roll bars.
    Wayne
    I want to see the video. Seriously though, I think ceramic is the best choice although I don't think they look as good in silver as does stainless or chrome. If you're going flat black, then ceramic is a no brainer. My Breeze quiet pipes were ceramic coated silver and eventually painted over with BBQ paint to make them back.
