Results 1 to 5 of 5
Thread: Exhaust System with catalytic converter
    Feb 2019
    I recently purchased an AC Cobra replica from a dealer in Nevada. When I went to register it I found out that it was going to need catalytic converters installed to be registered in Texas due to the way it was originally titled. I have searched far and wide and havent been able to find any solution for my problem. To be inspected in Tx, the converters must be visible to the inspector. Surely I am not the only one with this problem. Does anyone know of any vendors that sell an exhaust system available with cats installed. The only solution I have been able to come up with is to cut up my exhaust system and install converters for the inspection and then purchase a new system to run until next year at inspection time at which time i re install the cut up system for the inspection. Seems like a real hassle to swap exhaust systems each year. I would appreciate hearing how others have met this challenge. Car is titled as a 2001 AC Cobra.
    Sep 2018
    SF Bay Area, CA
    You didn't specify what engine you're running, but if it's a Coyote GP Headers makes a 4 into 4 header with built-in cats. Forte's sells them.
    http://fortesparts.com/index.php/pro...-side-exhaust/
    They may also make them (or be able to custom make them) for other engines.
    MikeB,
    Is your car a Factory Five and is it running a SBF?
    If so then this link may really help:
    http://www.factoryfiveparts.com/1426...ic-converters/
    Good Luck!
    Fairfield Ca
    MikeB,
    Good Luck!
    That's what I'm running on my car. Factory Five looks to be out of stock right now but I'm sure you can get them made. It's a simple solution.
    Good Luck. I thought Texas would be an easy state to register your car.
    Feb 2019
    Mine is a Mk 2 Roadster with a Ford 460 from Ford Racing. Will check with them tomorrow. Thanks for the reply.
