Thread: heater solenoid
    southern delaware
    heater solenoid
    i am trying to find out why my heater core is not getting flow. i have searched but not found a digram of fluid flow of the cooling system. the solenoid was installed with the labeled to "heater core" going to the core but i suspect since the other side goes to the expansion tank suspect the flow might be the other way. can someone please tell me which way this should be installed?
    Indiana
    I believe that is the Vintage Air unit? Upgrade to the one from MyRaceShop
    GTM #304 LPE 525hp LS3
    Mar 2018
    Plano, TX
    There's a thread on the "other" site that might help, I actually looked it up yesterday for my build.
    https://www.ffcars.com/forums/42-fac...direction.html
    Ryan
    GTM #511
    Build log: gtm.perkinsons.com
    Indiana
    southern delaware
    thank you!!
    i am not very knowledgable about this system. can you tell me how yours is better? thanks in advance
    southern delaware
    fyi yes it is a Vintage Air unit and yes they had it in backwards and now it works!
