Thanks Thanks:  230
Likes Likes:  228
Page 6 of 31 FirstFirst ... 4567816 ... LastLast
Results 201 to 240 of 1203
  1. #201
    Quote Originally Posted by M3ichael View Post
    And then there’s the famous new cover... It's like a toupee for an engine. Ford needs to design one for its crate motors.
    Great updates Sir Paul (I think you've earned the title)
    Thanks. I think. I expect to use the cover. Planning to anyway. But it's going to get a haircut. To use your metaphor.
  2. #202
    Wipers Plus
    My build plan includes wipers and I’m going to do washers as well. Both are required by the Michigan safety inspection. I’ve gotten away without washers on the Roadster builds thanks to sympathetic LEO’s. But not going to try again, plus maybe with this build the wipers and washers might actually be usable and necessary. But I don’t want to work through the Lucas drama for wipers again, so looked for an alternative. Found reference to a company Specialty Power Windows located in Georgia on several other forums. Seemed all good. They sell various performance car power windows and wiper setups, including a universal wiper system WWK-2. Pretty old school. You actually have to call them to order. What??? Found that Speedway sells their products, was in stock, and with a few clicks here two days later. Looked it over today, put together enough to see how it works, and have a basic plan for installing. The overall design is similar to the Lucas variety with a moving cable going through wheelboxes. But it’s quite heavy duty and seems rock solid. Configuration, direction, and amount of sweep are all adjustable. Also in my digging around, found reference to a wiper/washer switch that does everything the usual DD does. Push for washer and several wipes, variable intermittent, high, low, and park. Cool! The one I bought is a Cole Hersee 75600-04. They sell a bunch of variations. After studying the switch schematic and the wiper setup, determined this was the right one. Clipped everything together temporarily, and it all works as it’s supposed to. The wiper kit doesn’t come with arms or blades. Need to figure that out. But even once those are added, what I’m going to install will still be cheaper than the usual Lucas knock-off and I think (hope) quite a bit better.
    Had to chuckle a little bit. The literature says these wipers were the Best New Product of the Year at the 1991 NSRA nationals. My first reaction was these are maybe kind of an old design. Then on second thought realized that's 30 years or so newer than the Lucas style wipers. OK, that's progress. Here are some pics.
    Inside of main mechanism. Orientation of the drive wheel determines direction. Different holes to adjust the amount of sweep. The wheel boxes come with a long driveshaft that can be shortened, which I probably will need to do. Everything gets packed with grease when assembled for good.
    Motor and the Cole Hersee switch. I’ll be changing out the knob to match the others on the dash. Drive cable is in the background.
    Expect to mount somewhere in this vicinity. Plenty of room and should link up OK with the wheelboxes.
    I mentioned before about picking up the Breeze locking gas cap and installing into the LeMans cap. Got that done the other night. I’ve shown this including a full description in my other build threads, so won't repeat the details. Cut off the LeMans connection, hog out the flange for the regular cap, and bolt in. Not cheap, but an ideal setup IMO.
    Spent more time on the interior layout. Feel like I’m about there. There are some amazing interiors out there. I’m trying to stay within the basic boundaries of the stock layout though. I’m thinking of putting together a small center switch panel. The ends will be boxed in and have the aux outlets. Only switches on the dash itself will be the ignition, headlights and horn button over by the gauges. Probably going to go keyless push button start. Turn signals will be the Russ Thompson unit with headlight low/high/flash to pass on the stalk button. Four A/C-Heat outlets on the face of the dash, and I’d really like to install a glovebox. Probably can’t be real deep because of all the hoses behind the dash, but I’m going to try. I’ll have to do some fabrication on the DS to move things over a bit to fit the outlet on that side. Brow piece is still optional at this point. I’m planning to have the panel with the gauges removable which opens the dash area for access and servicing. Thinking of finishes of vinyl, C-F and some red stitching. Along the lines of how the seats are finished. Something similar for door cards as well. Again, very preliminary but it’s a start. What do you think? At this point changes are as easy as cutting more kraft paper and printing switch images.
    My first batch of powder coat pieces are promised for early next week. Also found out today Factory Five is sending out an update package for all Gen 3 Coupe buyers. There have been some sheet metal changes and maybe more. I’m really not sure. Some have gone out already. Mine is due in the next week or two. Good customer service Factory Five.
  3. #203
    Still Lurking & Learning!
    Thank-O-Million For Posting!
  4. #204
    Southern Ontario/Cape Coral FL
    Paul, looking good! If the gauges are going to be removable, maybe the brow mounting tabs can be mounted behind the dash or actually attached to the removable gauge section. That way the tabs wouldn't be visible, a little cleaner look. You've probably already thought of that though!
    Higgy
  5. #205
    Jan 2018
    opps
    Red stitching, means you pick your color? Guessing blue didn't make the cut.
  6. #206
    Quote Originally Posted by Wilder View Post
    Blue isn't off the table. But let's just say red is the leading candidate. Big surprise, I know.
  7. #207
    Body Off Plus
    It’s been a busy week since the last update. Still forging ahead. I was hoping to have some powder coat parts back and start installing. But haven’t gotten the call yet. But other things to talk about. I mentioned before we were going to have a Great Lakes Cobra Club event at our house. Happened last Saturday. Had a great turnout. After donuts and coffee, made it to the garage where I rambled for a while and then we just had a good time checking out the Coupe build, talking shop, and visiting with great friends. Then went to a barbeque place for lunch. Doesn’t get better than that! Hope my buddies don’t mind me posting these pictures. These are also in the public gallery on our club’s website, so should be OK here too.
    Today I removed the body for the first time. But first a few other updates. During the open house we set the nose on the chassis to see what it looked like (good to have lots of help) and I took the opportunity to measure the clearance under the area where I wanted to put the triple reservoir for brakes and clutch. Was 4+ inches, so the 3 inches I planned for them above the frame was fine. Should give good flow into the master cylinders. I was going to just tap 1/4-20 threads into the frame. But decided to use heavy duty nutserts instead. Was interesting working in that tight space. But got it done and the reservoir mounted. I mounted it with the caps level. The top frame member angles down toward the front. I think it’s going to work out well here.
    Also decided to make some progress with the wiper installation. Unlike the Roadster, the Coupe has the wiper locations molded into the body. Nice flat surface to bolt against on the outside but not on the inside. After drilling the holes centered at the right location, found it a little challenging to get the wheel box bolted in adequately. But the wiper system came with 5/8-inch long steel spacers that are intended to be welded into a steel body if necessary. Decided to use those. Shaped the ends so they fit into the contours in the underside of the wiper locations. Then spot glued with HSRF using the wheelboxes to make sure they were at the right angle. When that set up, put a pretty big filet of HSRF around each. Doesn’t look pretty, but doesn’t need to. The wheel box mounts are now rock solid and held perfectly at the proper angle.
    Cut and flared the tubes for the cable to run in.
    Installed where they belong.
    The wiper motor assembly came with a “universal” mounting plate that I didn’t use as is. Instead, harvested two pieces out of it, added as outriggers using the bolts already there holding the assembly together, and mounted some rubber shock mounts I had on hand. These will bolt to the firewall. I’ll get the final position and make up the last piece of tubing when the body goes on for the final fitting. I remain very pleased with this Specialty Power Windows (SPW) wiper system. It's kind of like the Lucas style system on steroids. Everything is bigger, heavier, and very solid. I've had it wired up a couple times and it seems to work very well. Now just need to find some arms and wiper blades. But plenty of time for that.
  8. #208
    Body Off Plus (continued)
    Today my side windows were delivered. These are new for the Gen 3 Coupe. Similar I guess as previous ones, but I really don’t know since I haven’t seen any others. I had seen some preliminary pics, but not the final version. Consists of a powder coated metal frame, plexi insert with a sliding panel (pre-assembled BTW), mounting brackets to mount it to the door frame, rubber gasket material to mount the window into the frame, and a bunch of hardware. Even comes with an installation tool for the rubber gasket. Interesting. No instructions yet so I’m not positive how it all goes together. The packing list did show two pieces backordered. Listed as plexi rear quarter windows. I'm assuming the kit provided scoops are replaced with a flat piece? Makes sense, but I don't know for sure. I won’t be doing anything with this for a while. I’m sure there will be more information by then. This isn’t the best picture, but snapped this pic with one of the frames and windows on my work bench. Not cheap, but I’m happy with the quality.
    So today I removed the body for the first time. I had hooks in the ceiling of my other garage, and had removing and installing the Roadster body all figured out doing it by myself. Pretty easy actually once you follow the proper sequence. I decided to try using my lift (watch too many car shows on Velocity I guess…) to take the Coupe body off. So put the chassis on wheel dollies, tied the body to the arms of the lift, and slowly lifted it off. It’s similar to the Roadster in that the sides need to pulled out to clear the undersides and door hinges. Also once it starts to move, needs to go a foot or more back to clear the back of the frame. I used towels wherever it was contacting the frame, trying not to mark up the powder coat. Took it slow and worked OK. But unfortunately, with the lift all the way up the body still didn’t clear the roll bar cage. So moved stuff around in the garage and was able to roll the chassis out of the way enough to set the body back down. I was going to use my Roadster body buck and modify as necessary. But it wasn’t even close. Would have been a complete rebuild. But in the end, decided a buck wasn’t even necessary. The sides of the body are straight and it sits flat on those with the back just slightly elevated. So I’m storing it that way with some blocks and towels under the back so there’s no pressure. It should be fine. It’s not particularly heavy. Maybe even lighter than the nose piece. But is a little bulky and floppy to move around. I decided to store it in the back of my Serpent Express trailer that’s parked outside by the garage. I don’t use the trailer too much, and it’s an easy in and out when I do. Also gave me a chance to see how the Coupe is going to fit into my 14-foot SE. Pretty much as expected, it doesn’t. Looks like it will stick out the back 6-8 inches which would keep the back door from zipping up. Still useable, but not ideal. Anyway, some pics. I've been used to seeing the chassis with the body on. Sure looks different now.
    Summary for me is that I was able to get the body off by myself. But 99% certain I won’t try that again. It would be really easy with a couple helpers, and that’s probably what I’ll do in the future. Next steps now will be to start locating and drilling aluminum panels.
  9. #209
    Paul,
    I've seen the pics from Factory Five on the new coupe window installed on Dave's coupe (on the passenger side). I love the fact that they are easily removable but am concerned about the bulky mounting brackets on the door (that the window frame bolts onto). The rear one looks like it could hit you in the shoulder and the forward one might cause a possible issue with the outboard knee. I guess a trip up to Factory Five to check out the window frame "close up and personal" would answer my questions. Any feedback from you would be most appreciated.
  10. #210
    Quote Originally Posted by Garry Bopp View Post
    Paul,
    Hey Garry. See, that right there shows how little I know about these windows. I didn't know the mounting brackets were exposed. Since I just took the body off, I can't easily simulate where the doors are or where the mounting brackets would fall. For me being average size, I'm guessing it won't be an issue. But for bigger/taller people, maybe. Will be interested to learn more and also see other installations.
  11. #211
    Paul,
    Here are the pics that Factory Five sent me, showing the window installation:
    Your thoughts?
  12. #212
    Paul,
    Your thoughts?
    Thanks for posting! Interesting. I'm not sure the mounting brackets will affect me. We're both pretty average size. The front one appears to be well above where knees would be. I think the back one will be blocked by the bolsters on the seats. The two things that occur to me right off though is I'll need to think how this is going to affect the door cards I was planning. Also can see it's a pretty good reach from the sliding opening in the window to the door handle. Some guys use poppers, but I haven't planned to. Probably still won't but will see how much of an inconvenience that might be, if at all.
    Also see they still have the scoops on the rear quarter. Just received shipping notice for another shipment on my side window order. I'm assuming that's the rear quarters that were back ordered on the shipment earlier this week. Also assuming they will be flat panels. Or maybe they just block the scoops somehow? We'll see.
  13. #213
    Oxford, Michigan and Scottsdale AZ (winters)
    Summary for me is that I was able to get the body off by myself. But 99% certain I won’t try that again. It would be really easy with a couple helpers, and that’s probably what I’ll do in the future. Next steps now will be to start locating and drilling aluminum panels.[/QUOTE]
    Paul, Call or text my cell (248)765-1822 anytime if you need help, especially something a quick as lifting the body on or off. I drive by your place at least twice per day!
  14. #214
    Quote Originally Posted by tcollins View Post
    Thanks Tim. I will definitely keep that in mind. Much appreciated.
  15. #215
    Hi, Automan out of Ontario Canada building Gen 3 #50. Did you setup your car as race or street mode for the suspension. I wont be racing mine but im temped to set it up for race because it will be much lower. Of course its the street bumps that i have to watch and driveway entrances.
    What are your thoughts.
    Thanks, Automan (Nelson)
  16. #216
    Thanks edwardb, this is really helpful. I like the look of this wiper system for my 33HR.
  17. #217
    Quote Originally Posted by Automan View Post
    I used the lower "street" holes. I don't know that the inch or so difference is "much lower" but it would make a difference I guess. For street driving, I'm not really interested in it being any lower. I've done pretty OK with the approx 4-inch ride height on the Roadster's I've driven. I'm expecting this will be the same. BTW, the biggest issue I've had isn't the frame itself but the overhang on the nose. Real easy to catch curbs or driveways. Not interested in that being even lower.
    As a side note, if you (or anyone else reading this) has the dual-action Koni shock options, they go in the top hole even when putting the rest of the suspension in the "street" holes. It's noted in the instructions for the front suspension. A little hidden and easy to miss in the instructions for the rear suspension.
  18. #218
    Macedon, NY
    I wish they made them slide in and out like a jeep wrangler style window.
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
  19. #219
    Mar 2017
    columbus ohio
    A little late to the party, just came across your thread. Too much to read and not enough time available.
    An alternative to using the T-56 is to use a 2015-2017 Mustang MT-82 tranny. Biggest challenge is the shifter is about a foot too far back. We recently developed a top mount shift mechanism that will be available in about a month. Here is a pic of our interior with the shifter installed on the Mustang tranny as a pic of an early prototype of the shifter mechanism that was machined and 2018-01-12 12.59.37-LR.jpg2017-05-17 15.31.20-LR.jpg3d printed.
  20. #220
    Aluminum Panels – Here We Go
    Started serious work on the getting all the panels fitted, drilled, etc. prior to powder coat. Including installing the trunk box fabricated and shown earlier. But first some observations. While there are some similarities to the aluminum panel layout used in the Roadster, they are of course all different parts installed in a different sequence. Before removing them, I spent a lot of time reviewing the instruction manual confirming how they are installed, overlap direction, etc. I quickly realized that panel installation is in multiple places in the manual. I ended up taking quite a bit of time searching and finding all the panel installation steps (electronic version of the manual with searching is nice), listing them in sequence, and also listing the major steps between.
    What I found is that 29 aluminum pieces are installed before the body, and 24 after the body is installed. That’s very different than the Roadster, where all the panels except the splash guards and a couple pieces by the radiator can be mounted without the body installed. Explains why I had a little more trouble than I should have removing the body. Also has me re-thinking how I’m going to do heat and sound insulation. Some of the pieces that aren’t installed until after the body are the sides and rear for the hatch/trunk area and the rear cockpit corners. I’ve masked and sprayed Lizard Skin on all of my builds, and was planning to do the same for the Coupe. But that was already looking a little tough with the additional obstacles (roll cage, etc.) and now not having all the panels installed first. Has me thinking as well about maybe putting insulation on the outside of the footboxes. Something I’ve avoided on previous builds because I’m not a fan of the look. But that might be the best solution here. More thinking and planning ahead on this subject.
    One other observation. For the Roadsters I’ve found the panels were installed in the shipping locations with all the overlaps the direction they were supposed to be installed. I didn’t find that to be the case here. The pictures and sequence shown in the instruction manual has a number of differences from how my kit was received. No big deal. Just an observation and something to watch.
    Back to actual build progress, cut the hole in the floor piece, fit the trunk box around the frame rails, and have the floor and box cleco’d in. Happy with how it turned out. I’ll install the folding cover later after installing carpet. Next week I’ll finish the hatch/trunk area, work on the cockpit, and probably take the block and transmission back out so I can start working on the footboxes.
    This is pretty minor, but after a couple tries found a shift lever I’m happy with. 6-inch long Hurst 5387201 is a good length and angle for my setup. Chrome plated steel so a nice solid piece, and wasn’t expensive. The shift ball is one that came with my TKO on the last build, so not the right shift pattern on it. I’ll need to find something similar for the T-56. I’m impressed with how easily and precisely the T-56 clicks through all six gears. I think it’s going to be a winner.
    One last follow-up item. Received the Gen 3 side windows as described and pictured in a previous update. There was an open question about the rear quarter windows since the kit comes with a scoop for that opening. Not too useful if you’re trying to keep the elements out. I received the backordered quarter windows that go with the windows. They are designed to go on the inside of the quarter window opening. The outside scoops wouldn’t need to be removed. But the inside panels would close the opening. Maybe the previous Coupes were the same way. But this is new to me and I had gotten a question or two.
  21. #221
    Thankyou, i will set mine up in street mode also. Great point on the noise rubbing!!!!!
  22. #222
    Still At It
    Work on fitting and drilling panels continues. Rear hatch area almost done. Making good progress on the cockpit. Still on the same new drill bit I started with. (Probably shouldn’t say that…) Everything is fitting pretty well. Mainly just the usual minor tweaks on bends and needing to trim around welds occasionally. I’m planning to have the two front transmission covers removable. So will use countersunk rivets along the top edge of the floor pieces. That front hatch floor piece (removed in this picture, but just behind the rear cockpit wall ) is a bear. No less than four pictures in the manual showing exactly how to bend it to get in and out. Still not easy. Put some heavy duty tape on the roll bars or you’re liable to really scratch up the powder coat in the process.
    I had this in my last build thread, but will show again. This 6-inch seamer/bender from Harbor Freight works great to adjust bends for this work. I use it a lot at this stage. https://www.harborfreight.com/6-inch...mer-98728.html
    I mentioned before about needing to get a shift ball that I liked plus had the T-56 6-speed shift pattern on it. Then I was reminded that Tremec offers them for free if you go to their website and register your new Tremec transmission. Done. They have several varieties and either SAE or metric adapters. Nice quality pieces and the price is right.
    The weather is finally starting to warm up. Hopefully will be able to get #8674 out of the garage soon and get some driving in. Will cut into build time. But I’m willing to make that sacrifice.
  23. #223
    Livermore, CA
    As always, looking great and the speed of your progress is amazing.
    One drill bit to drill all those holes? Please tell me your secret, I've gone through about 5 Dewalt cobalt bits to drill half as many holes as you. What bit are you using? Are you using any cutting oil?
  24. #224
    Colorado
    I would also love to know what kind of drill bit you are using. Things are looking good and thanks for pointing out the 6 in seamer/bender. You have to love cheap tools that get used a lot.
    I had a couple quick questions about the DA Koni shocks on your coupe. Are you able to adjust both the compression and rebound while they are on the car? If I remember right, the single adjustable ones needed to be taken off to be adjusted. Also, did you go with the standard springs from FF? The shocks I put on my daily driver are compression and rebound adjustable which allowed me to put on softer springs and improve the ride around town. When I go to the track or to AutoX, I am able to stiffen up the compression enough to make up for the softer spring. I was hoping the DA Koni's also allowed for a softer spring. Thanks.
  25. #225
    The drill bits I use are "Aircraft Grade Super Cobalt" from http://www.aircraftspruce.com/catalo...obaltdrill.php. I don't know if they're any better than your off-the-shelf cobalt drills at HD or whatever. But they are decent quality and the price is right. I ordered some #30 and and #10's before the last build and still have a few left over. As I said, I probably shouldn't be talking about it. I break my share. Probably went through at least 7-8 #30's in the last build. Don't usually break the #10's. They're bigger plus just not used that much. In my experience, the number one thing that breaks them is drilling into welds. Will snap them in a heartbeat. I've been being careful to not do that. Also maybe the fact that the coupe is all square tubing helps. Not deflecting or getting off axis in round tubing like sometimes drilled on the Roadster. But mainly I'm probably just lucky, and will probably break the one I'm using later tonight. I don't use anything on the bits. I know some guys use oil or wax. Normally I don't.
    Yes the DA Koni's can be adjusted without removing them. The adjusters are visible in this picture from the #8674 Roadster build. The bottom one (compression) is the screw just above the lower mounting bolt. The top one (rebound) is the horizontal slot just below the top mounting bolt. It's a wheel like piece that you can turn with a pin through the slot. I run them both at full soft. I'm nearly positive FF supplies the same springs with the DA Koni's as the standard red single action Konis. #8674 has the exact suspension components as the Coupe. I've driven it a couple thousand miles, and don't find the ride uncomfortable at all. The IRS is noticeably more comfortable than the solid axle setups I had before. Maybe the ride could be more compliant, but I'm very happy with how it is now.
  26. #226
    Powder Coat Plus
    Received the call late last week that my first batch of 39 powder coat parts was done. I’m expecting some updated aluminum panels from Factory Five soon. The cockpit is fitted and drilled and just a little more to do in the hatch area. Then I’ll stop and wait for the updated panels. Meanwhile, picked up the powder coated parts and worked with those for a while. These I had done in gloss black to match the chassis. Mainly all the fabbed metal parts and the radiator tunnel and shroud. I’m planning to do the second batch, all the aluminum panels, in a similar silver as the Anniversary Roadster. Like the color, it’s easy to take care of, and looks good against the gloss black.
    Everything looked good. Lots of parts. I know not everything will be visible once complete. But still like to have everything coated.
    Installed the fan shroud and fan on the radiator. Not too visible here, but the fan shroud was just slightly too tall for the mounting on the radiator. Plus it needed to be up slightly at the bottom to not interfere with the tunnel because of the angle it sits at. So before powder coat, riveted a strip along the top with a spacer between. It slips down over the top of the flange on the top of the radiator and only has bolts on the bottom. They did a good job of keeping powder coat out of the slot. It was a tight fit without any coating.
    I won’t mount the tunnel pieces or radiator permanently until after the engine is installed. Just makes it easier to reach, plus keep from banging things up. So just a couple clecos for now to see how it looks.
    I spent some time assembling the door frames, hinges, door latches, handles, etc. Thought about cutting the doors open and installing the frames. But decided to wait until full on body work time. No need to be making fiberglass dust just yet. Plus I really want to fit the doors in the body before cutting anything. But still went ahead and temporarily put the door frames on the chassis. Everything fits and works really well. Very happy so far.
    The hinges I had welded, shown in an earlier post, turned out really nice. The hinges and bear claw latch are rock solid. The hinges and part of the frame are exposed out of the front of the door.
    Another builder posted a picture of the new Gen 3 windows and the mounting interfering with the door handle. So checked that out. Using the just received windows, determined where the mounting will be on the doors. Then where the instructions show to mount the inside door handle. Everything is fine. Clearly this has been sorted out. Also figured out the window brackets lower mounting bolts are intended to be through the door frame inside the door. Good. This is rough, but how things lay out. I’ll cut and drill later.
    Another small project was to finish and install my in-tank fuel pump. I had everything I needed except for the step-down butt connectors. Received those, so finalized the assembly and installed in the fuel tank. The tank is ready for final installation. The connectors I ended up using are Molex 19164-0077. From DelCity, but available elsewhere. They’re crimp and heat shrink, and advertised specifically for harsh environments including gasoline. On #8674, I used similar connectors from West Marine, although not specifically listed for gasoline. I soaked those for a couple days and determined they were OK (and made for some interesting banter in my build thread…). But these look better. Minimum order was 10, so I had extras. I took the opportunity to practice and pull test the joints before installing them for real on the pump. Good thing. My first choice for the dies on my crimper didn’t work too well. Sorted that out and I think they came out fine. As mentioned before, this is a Pro-M Racing High Flow fuel pump hanger. Has full 3/8-inch supply and return lines and -AN6 connections. You can see in the pic how the return line goes to the bottom of the sump. Because of that, it’s a little challenging to install. The instructions show how to cut the fuel tank opening to allow it to fit in. I found you don’t have to cut it quite as much as they show. But still is necessary. That plus the usual twisting and turning to get the pump and filter through the opening and into position. So if you decide to go with this hanger, obviously best to do the trimming before putting fuel in the tank. I used a Walbro GSS340BX 255 lph fuel pump. Lots of discussion about what size pump to use with the Coyote. This is the same pump and fuel line setup as #8674, which has proven to work well.
  27. #227
    Powder Coat Plus (continued)
    Last up, received my Russ Thompson turn signal setup. Have been on the waiting list for a while, but sounds like he’s got another good supply of the VW turn signal assemblies so is now filling orders. He was still proving out the exact setup for the Gen 3 Coupe. Worked with Mike Everson on his build, and then sent me several different spacers with instructions to try. Was pretty easy to get sorted out and installed. I like this top mount better than the angled bottom mount used on the Roadsters. As I understand, new Roadster kits have a similar steering column mount now.
    Was really hoping to be driving #8674 soon. Woke up Easter Sunday morning to snow. Grrr! It’s gone now, but still pretty chilly out. Come on. Meanwhile, plenty to do on the build.
  28. #228
    Jan 2018
    I would say waiting patiently for Stewart Transporting... well we will just say waiting and rereading every post. IMG_1426.jpg
  29. #229
    Too funny. Your kit will look better though. Just saying.
  30. #230
    Two things Paul:
    1. You said "Thought about cutting the doors open and installing the frames."
    I am not familiar with how these doors work. You have to cut them apart to get the frames in? Could you expand on this a bit.
    2. Is it possible to post a picture of how you had to cut the fuel tank?
  31. #231
    Two things Paul:
    Good questions. Unlike the Roadster, where the welded steel door frames are sandwiched into the door shells when they are molded, the Coupe has somewhat similar door frames that are installed inside the door shells by the builder. Maybe because the door frame and hinges extend out the front of the door shells to have the required geometry. Maybe also because the bear claw style latch and door handle/cable are inside the door. Or maybe neither of these reasons. Regardless, the instructions show cutting a hole in the front edge of the shells and the frame is slid in through this opening. It's held in place with four through bolts against the inside half. They are accessed through the center panel which is also cut out. This picture shows roughly the area shown in the instructions to remove, plus the center area to remove is visible. That center area was also visible in the picture I posted previously. Once the frame is installed, another cutout is made on the back edge for the striker to engage the latch. I was going to get the air saw out and start cutting. But then decided to wait until body mount and fitting to confirm the size and location of the cutouts before proceeding. Several Coupe builders have confirmed this approach.
    For the tank with the Pro-M hanger, I can't show my actual tank modification because it's covered with the now installed pump assembly. But here's a picture of the page in the instructions. Shows the stock opening and then how it needs to be modified. The cuts stay inside the sealing area, so that's unaffected. As I mentioned in the post before, I didn't find it necessary to cut quite this much. Specifically the wide cut I found only needed to be about half that wide.
  32. #232
    Paul,
    As always, I enjoy watching your build progress.
    I still don't think I've got what it takes to build this car so, but that's okay.
    Thanks for letting us all ride along as you create your latest Masterpiece.
    Mar 2017
    columbus ohio
    Not sure if you have checked but the "symmetric" car is a bit asymmetric. On one of the two doors in our build the inner door skin recess was about 1/2 to 3/4" inches longer than the other side. The frames, however, were symmetric and therefore the one of the frames required cutting out and re-welding a tube shifted by nearly an inch. Ours was the 4th or 5th production Gen 3 and FFR may have corrected this issue.
    Quote Originally Posted by Chris @ Forma View Post
    Obviously I have no way to know at this point. I will find out when I get to that point of course. I know there have been some changes. Mine is #59, and has differences even compared to others not much earlier than mine.
  35. #235
    Edmonton Alberta
    Mine #16 and the door frames fit the skins fine so they must have fixed it
    David W
    Mkll 4874 built in 2004
  36. #236
    Huntsville, Al
    Mine was that way as the beta... and I passed that to FFR... so this should have been corrected
  37. #237
    Aluminum Panels Again
    Finally, almost done with getting all the aluminum panels drilled and fitted. Everything is done except a couple around the footboxes, and I’m still not sure what is coming in the update package. So, will stop until that arrives.
    The instructions don’t say anything about access panels (like on the Roadster DS footbox) or leaving the footbox top(s) removeable. At least that I found. But clearly it’s necessary. On the DS, provides the usual access to the Wilwood pedal box, master cylinders, etc. On the PS, with heat and A/C, also necessary IMO. The heater hose connections would be basically inaccessible without the top open. After considering the options, and also looking at Mike Everson’s build, decided I didn’t want or need the entire top panels to be removable. So I cut them roughly in line with where the body cowl extends over them. Added a small piece on the back of each panel that slides under the fixed portion. I’ll rivet those pieces on after powder coat. I’m using 10-32 SS flange head screws for hold downs and was originally going to just tap the threads into the frame tubes. But decided after doing a couple that there were only 2-3 threads, and since these could be used somewhat frequently, went ahead and put nutserts at each location. I ground down the welds some where the covers fit which allows them to sit down a little flatter. Also added nutserts for the heater control valve which mounts on the PS cover.
    Next up I worked on installing the bulkhead connectors for the A/C and heater lines going into the PS footbox. Factory Five supplies very nice Vintage Air bulkhead connectors, and the instructions are quite detailed on how to locate and install them. Unfortunately, I managed to make a giant mess of this. I started with the A/C one, and here because of how short (and stiff) the lines would be inside the footbox, the alignment is quite important. After very carefully (I thought) checking and re-checking, drilled the holes, and (you guessed it) wasn’t really very close. The angles of everything make it pretty hard to figure out the exact location. At least for me. I adjusted the holes repeatedly until the alignment was OK, and at that point the bulkhead connector no longer covered my original holes. Grrr… So made little filler plates for each side that I flush riveted in place and are sandwiched in the bulkhead connector and all was good.
    Moved to the heater hoses and this time spent even longer making sure I had the right location. Checked, checked again, checked the angles, etc. Went for it. Drilled the holes, and you guessed it. Missed again. By almost the same amount. Crazy. Found the right location, made another pair of filler plates (getting good at this…) and now that one is also done. The amount of time I messed around with this is one of the many reasons I’ll never make it into the 200+ hour club for these builds like the pro builders. I actually kind of like how the filler plates make the bulkhead mounting a little more solid in the footbox walls. But wasn’t in my original plan to do that obviously. I’ll make up the hoses when everything goes back together after powder coat and insulation. But looks like this for now.
    I made a new transmission cover. Had enough scrap aluminum and just fits into my little Harbor Freight brake. I decided it was easier to make a new one than to patch the shifter hole that was not centered on the T-56 shifter location. I’ve had to address this somehow on every build. I personally think it would be better if Factory Five would leave these blank and let you cut the hole yourself in the right location. I also used the opportunity to adjust the width/bends just slightly for my planned upholstery wrap of the cover. Still planning to make it removeable, plus likely the one in front under the dash as well.
    Moved to the sheet metal in the hatch/trunk area. Everything there is now fitted and drilled.
  38. #238
    Aluminum Panels Again (continued)
    Starting to look pretty serious. Note in this picture, the rear hatch wall, the two hatch sides, and the two cockpit sides (behind the seats) aren’t permanently installed until after the body is installed.
    Two other things:
    I’ve been asked why there aren’t lock nuts in the pictures of the door frames I posted before. This points out a practice that I’ve made part of my builds that I’ll share. Where parts are going to be mocked up and repeatedly installed and removed (which happens a lot), I don’t use the supplied lock nuts until final assembly. In this case, Factory Five provides some very nice nylon insert locking flange nuts. But they’ll stay in the bag until the doors go on for the last time. Lots of discussion here and elsewhere about whether these kinds of nuts should be reused, how many times, etc. I’m just cutting through that and not using them any more than necessary. I have a bin of the common size nuts used on these builds (5/16 and 3/8 mostly) and those are what I use during the build itself. They’re easy to take on and off during initial assembly and mock-up, which is another advantage. Some of these are veterans of multiple builds.
    Finally, I have a question for other builders regarding the front cowl mounts. I checked the fit of the mounts in the cowl and I’m not sure about what I’m seeing. The mounts attach to the cowl with two bolts through the back of the running light buckets and another one on the lower part of the cowl. The mount is angled (roughly about 3 degrees is what I measured) but this doesn’t match the angle between the back of the bucket and the cowl. The result is a gap that would seem undesirable. I’m thinking for sure mount the bracket flush on the back of the light bucket. Then use a spacer or some washers on the bottom mount? I’d rather have the entire face of the mount flush against the fiberglass though. Maybe make up a wedge or build it up with glass? Thoughts? This picture hopefully illustrates what I'm talking about. The gap isn't real clear in the picture, but it's where annotated.
    Planning to start working on the interior and fabricating my dash layout. Haven’t checked in with Ford regarding the Gen 3 Coyote for a while. Probably need to do that too.
  39. #239
    It's not how good you are, it's how well you cover up your mistakes....
    I like the bulkhead doublers. They look like they should have been there in the first place.
  40. #240
    Huntsville, Al
    Two other things:
    I cut mine and rewelded it to sit flush
