Off to Buttonwillow Saturday. Running 13CW. Running with Speed Ventures. I am a little nervous. It was one year ago that the motor died at this event, started on the trailer. Weather is supposed to be perfect: 40 - 65, sunny with light winds. Report to follow. New shift cables and some changes to the dry sump return line plumbing: scavenge pump - cooler - spintric - tank. Running some Hoosiers with good "tread", but probably 25 heat cycles. Just interested in getting a feel for the new shifter cables and assessing temps (oil and water) with the dry sump changes.
