I honestly don't know. Their website has a dimension chart. It's the last one on the images list: https://corbeau.com/sportline-evolution-x.html. You could compare these dimensions to your Kirkey high backs. I've only ever installed the traditional Roadster low back seats in my Roadster builds. So don't have a sense of what else might fit. Good luck.
). The panels are different shapes and sizes of course. But the panel overall layout is similar. Some of the big differences are still ahead. Heat and A/C. Very different instrument panel. Different door hinges and latches. Very different glass. And of course the body is also very different including the tip-up nose (unless you're Jazzman or 2bking). In general, the fit of everything is quite good. The body looks like it's going to fit up well. Based on everything I've heard and seen, it's an easier build than the previous Coupes. Generally, the Coupe was not recommended as a first build. I'm still a long way from done so I might change my mind. But I'm not sure that's the case any more. Those are my random thoughts after being maybe 15-20% in.
