I had the same thoughts. Keep in mind, the FFR Setrab cooler is set up for -10 AN fittings. The high pressure power steering lines are much smaller. You can make it work with reducers but you will need to play with the hoses and fittings. I figured the big -10 lines coming off of the cooler were a big part of the look so changed my plans. It can be done but you need to plan it through.
