is it possible to use the 3.6L direct injected V6 with an aftermarket turbo in the GTM? i realize the LS motor mounts would need to be changed but would the mendeola transmission still be pheasable? if not is there a 5-speed unit that could work? i realize that the car is set up for a LS style V-8 but im going more for throttle response and low- to mid-range torque , plus the wieght savings should help a little. I'v only started researching this car and am already considering it over an EVO, however i do plan on buying the kit last and having the other parts not included in the kit ready and waiting. any help on these matters would be greatly appreciated.
