42
48
Papa
I'll defer to the experts, but when I was installing my FFMetal battery box, the install directions stressed not putting the box in front of the two tank mounting bars. This is to ensure that the tank can move forward in a rear end collision. With the modifications you are making, your tank won't be able to move if you get hit.
Thanks for the advice Papa. I'll definitely look into this. I'm pretty sure I will have the battery in similar position as the FFMetal box except on its side. I will post more photos as I go which should make it more clear.
