Results 1 to 6 of 6
Thread: Ford 302 / 5.0L for sale - SOLD
    Grand Rapids, MI
    Ford 302 / 5.0L Motor $3,975
    New never run. This was built for the FFR Challenge Series over the last year.
    Remanufactured 302/5.0L short block done in 2016
    Trick Flow upper end kit, including
    Aluminum cylinder heads (170 CFM, 2.02/1.60 valves), upper & lower manifolds, 24# injectors, 70mm throttlebody. Cam (hyd roller 275 duration, .499 lift), pushrods, timing chain, 1.6:1 roller rockers, valve covers, oil fill kit.
    Edelbrock timing chain cover, Ford water pump p/n M-8501-C50, Distributor, ECU, blueprinted Precision Pumps oil pump
    Canton oil pan p/n 15-630s, and pickup
    Ford Harmonic Balancer p/n M6316-A50
    Mass Air Sensor, conical 4” air cleaner
    Trick Flow product information indicates 370 torque and 350 horsepower for this combination.
    Also available
    Ron Francis Ford EFI Harness P/N Cobra-75 unused in original box $400
    A Ford flywheel, Ram clutch & pressure plate. All are new in original boxes. $375
    Ford Flywheel p/n M-6375-B302
    RAM kit p/n 88784 10.5 x 1-1/16 10 spline
    Disk and T/O bearing, both still in original package
    BBK Tuned Length Headers, Polished ceramic coated , 1-5/8” P/N 15120 $275
    Fits 1986-1993 Mustang 5.0 50 State legal Never used Original box
    I’ll entertain offers. Shipping / transport is extra and will require a skid and box. Would rather arrange pickup. Located in Grand Rapids, MI.
    Please PM, we can exchange necessary information from there.
    Jim
    Good morning- I am interested in the engine you listed here. Would you be willing to let it go as a long block? (i.e. minus the manifolds, injectors and throttle body stuff.) I would also be interested in the flywheel and clutch assembly. I would need to have it shipped as I am a bit further west than Michigan. Thanks, Wes
    Grand Rapids, MI
    Wes,
    Sent a PM a few days ago. We can talk about the package you're interested in.
    Jim
    Dec 2011
    Jim
    interested in the engine and wiring. are you coming to autobahn? bring list of part# used to build engine. we cane talk at autobahn
    Lyle
    Grand Rapids, MI
    Lyle,
    Sent a PM with more info.
    Not going to make it to Autobahn.
    Jim
    Grand Rapids, MI
    Sold the 302 to a local friend. All are happy.
    Thanks to all that asked about it.
    Jim
