If you haven't seen the little metal retainers that come with the FFR headlight set you won't believe how weak they are. They just are not up to the task. I have seen another fix that required bending up some new retainers and even a mention of silicone to hold them steady. What ever works for you. I had had enough of the bendy little rascals so it was time to take them out. A little scrap aluminum and a few minutes on a bandsaw and its problem gone. The photos should be enough to get you going on your own fix.
