Front UCA - MK4
The manual shows that I should have 4 flanged bolts and nuts to mount the UCA's. The parts list only shows 2. I only received 2 bolts and nuts in my kit. I don't have any other extra bolts in the kit to mount the UCA's.
Is the parts list wrong? Should it show 4 bolts and nuts? Should I have received 4 in the kit?
Scott
Scott,
The MK4 upper arm location changed you should have two non flanged bolts that were packed with the spindles.
Rick@factoryfive
Thank you Rick. Since my LCA's and spindle hub nuts are on backorder, I didn't open the spindle box yet.
