Results 1 to 2 of 2
Thread: Hardware for tranny mount and mounting to engine
    May 2013
    Colombia
    Hey guys,
    Since I'm not using a donor, I need the subaru part #s or specs for all the bolts/nuts, etc that are required to bolt the tranny to the tranny mount, the tranny mount to the frame, and the tranny to the engine. I'll be using a group-n tranny mount and a diy adaptor plate to mount the tranny to my motors, but I'd like to keep it OEM in terms of specs at least.
    Thanks in advance,
    Speedy G
    They should be a m12x1.25 pitch you will need diff length though depending on the hole. Grade8 is always safe bet!
