Results 1 to 10 of 10
Thread: Quaife Diff for 2007 WRX 5 Speed
    Oklahoma City
    I am really confused now that I have read the transmission sticky and then ran across this thread:
    http://thefactoryfiveforum.com/showt...-The-Race-Line
    The Quaife web site lists the QDH3Y as having female output like my 2007 5sp transmission and shows it is applicable for all non-STI trans:
    https://shop.quaife.co.uk/catalogsea...3&model=510&q=
    All the other info I have found (and listed at other vendors) indicate I should order the QDH1Y which has male output shafts (again, my trans has female ends) and use earlier axles with female joints. The Quaife web site above indicates I should order the QDH3Y which does have female ends. Will the QDH3Y fit the 2007 5 speed is the question.
    The reason for all this rambling is i have found several new Quaife QDH3Y diffs available for under $700 delivered, quite a discount from the ~ $1,200 or so for the QDH1Y plus a change of axles.
    I am probably opening all kinds of discussion again even though this issue probably been thought to be closed and answered! I will appreciate any input and will go hide again until the next crisis!
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    You want the QDH3Y. It will work with the axles and CV joints that you have for your year donor.
    Here is my write-up on installing that exact part in that exact year transmission: http://thefactoryfiveforum.com/showt...ions-with-pics
    Oklahoma City
    Thanks again for your write up about the LSD install and confirming the QDH3Y was the correct part for this install. I am ordering a diff Monday and see if it is as advertised especially at the price. I will update when received so if others want a diff they may order there own.
    ~ Mark
    Oklahoma City
    Received the Quaife differential today and it is as advertised. Trial fit looks good in the 2007 5MT trans this afternoon. If this is of interest, search eBay for a 'Quaife QDH3Y' and there are several listings but the one I purchased was from autotech_sport_tuning for $654.00 delivered. Quite a deal. This unit is for male axles (the diff has female input stubs). Thanks to Hindsight for confirming this part number.
    ~ Mark
    Nov 2015
    Caledon, Ontario
    That is a great price fastzrex. Thanks for sharing. That makes getting an LSD so much more patatable. Off the fence now, and on the two-wheeled peel side, lol! Hindsight, I guess that same number would work in an '05 5-speed?
    Mar 2015
    Houston, Tx
    Yeah I bought the QDH3Y from the same vendor last week. It's been on my list, but I've been putting it off. When I saw this thread last week I looked it up, saw the price and immediately ordered. It comes out of California. Delivered as advertised and a little quicker than quoted. Still about a month out from starting my build (I'm overseas) but that was one of the last pieces I needed to get started.
    Hindsight's Avatar
    Atlanta
    Quote Originally Posted by THE FURNACE View Post
    If the 05 has inner CV's with male ends that fit inside of the transmission (differential), then yes. So just look at your CVs and that will tell you. I THINK 05 was the first year for that, but it could have been 04.
    Anyone used the MFactory diff yet or will I be the first?
    Nov 2015
    Caledon, Ontario
    Thanks Hindsight.
    Our transmission is definitely an "innie".[ATTACH]65105
    This is my first photo post. See if it works.
    Nov 2015
    Caledon, Ontario
    I just shelled out for an LSD. I've done many motorcycle gear boxes back in the day, but I'm sure that Hindsight's write up will definitely come in handy.
    This is a great forum!
