... Your bigger problem may actually be in the rear. Did you swap out the axles for shorter ones? If not you may have rubbing on the rear fenders with the stock length axles. You may need to purchase shorter axles and offset brake brackets. There are a number of vendors on this forum that can supply you the parts you need.
My thoughts exactly.
