Sorry for not replying to the last question. Update on my progress, ok today I followed the segestion that possible I had a diode backwards which I believe I possible did, so I took it all apart ( my wiring) and re-did it to the schematic well one of the schematic that came with the column, it was the diagram with the turn signal wire (+) that is just to the flasher feed and the hazard flasher is connected to the SPDT switch. Anyway it did the samething I double triple checked my work diodes and all, it's all correct, so I said screw it and made a hot jumper wire and put it to each wire I assumed was my individual lights (LF, LR, RF, RR) and THREE outta four, they are all separated mind you. And THREE outta four made all the lights come on. So it's obviously in the harness and not my wiring(wahooo), so does anyone have anymore suggestions cause I'm going to just run my own wires now instead of fighting these damn lights anymore. Ok thanks to all who replyed....
