Ok I have searched and searched, cut and rewired, put in different circuit (two separate flashers), wired the stock donor single flasher. We are using the VW column and I've tried there diagram. I'm completely frustrated and out or ideas lol, please help someone lol. What is happening is when I flip the turn signal switch to either side both lights are coming on as if I turned on hazards, hazards work fine. Just having a problem with the turn signals. I've wired it exactly how the diagram that came with the column says too.
Ok Question #1: Does anyone have a diagram or schematic for the plug with all the wires for the headlights high/low beam, RR/RF TURN, LF/LR TURN, and Hazards thought I had it figured out but obviously not?
Question #2: Has anyone had this problem, and if so what was there solution?
Please help and thank you for taking the time to read this...
